Power/Pressure washers
Rico1111
Rico
RI
2018 Rubicon 2 door JL
Love the colour of that blue Jeep. Awesome.
Thanks! yeah I fell in love with it at first sight. It is a great color and now it' s showing up on a lot of other vehicles. pic before adding winch etc...
Jeep Wrangler JL Power/Pressure washers IMG_4165 (1)
Strommen95
New York
2019 Jeep Wrangler Sport S Unlimited
Any electric pressure washer will do for a vehicle. I would personally skip out on the foam cannon. Other than looking cool, it doesn't do anything except waste more soap than a normal wash. The end result is the same.
swozey
Denver, CO
JeepVet74
JeepVet74
Jenn
Chattanooga, TN
2020 Mercedes AMG SLC43; 2022 392 XR
Gobirat
Gobi
Midwest
Jeep 4XE
One of the reasons the detailers like the cannons is that it can dwell on the surface and break down the dirt before agitation with a wash mit. So the heavy layers of dirt can run down the vehicles surface before even touching it and stirring it into the paint. It also lets you see well where you have been, and when using presoaks it lets the chemical cling to the surface and and start the breakdown action. But yes it does look cool and it does use a lot of soap like you said.
ek1
People's Republic of New York
Private
Need some help here. Did a little mudding yesterday, now looking for a few things to get the mud off the Jeep.
I already have a garbage Portland 1,750 PSI pressure washer from Harbor Freight. It works perfectly fine and I actually like the fact that it's very low power...much safer on cars.
My problem is - I need to buy a bunch of accessories/attachments to wash everything properly - for example an undercarriage washer, some extra nozzles, wands, hoses, etc. and I don't know what will or will not fit, what connector sizes are, etc.
Here is my washer: https://www.harborfreight.com/lawn-...pm-corded-electric-pressure-washer-63254.html
Here is the connector on the washer:
Jeep Wrangler JL Power/Pressure washers 1680458497710
...it connects to this hose:
Jeep Wrangler JL Power/Pressure washers 1680458524999
This is the connector on the other end of the hose:
Jeep Wrangler JL Power/Pressure washers 1680458565121
....and it connects to this sprayer:
Jeep Wrangler JL Power/Pressure washers 1680458605327
The connector on the sprayer is like this:
Jeep Wrangler JL Power/Pressure washers 1680458633724
And the wand on the sprayer can be detached like this:
Jeep Wrangler JL Power/Pressure washers 1680458674553
The ONLY thing I don't want to replace is the pressure washer itself.
I want to get something like this: https://www.amazon.com/MINGLE-Press...7c74080f35&ref_=pd_gw_ci_mcx_mr_hp_atf_m&th=1 and something like this: https://www.ebay.com/itm/265835253534?hash=item3de5040f1e:g:KOUAAOSw1kJi~L8N&amdata=enc:AQAHAAAA8MfUI1Xw6UNEnADoDdXgE4O7ixmV/gAu25aQp+/1edtY1y7HFzwHmpQQt4NhO4dnMkwTH751uDS5WQNZOjRZagiDu0inJWvbM280T2gpkJeGRRp59a3qFudREvCwmthySadWzl+kJfrXzgRjGlzEc4u84ZFf0HuNjbDfr1UgBuKIJAZp4oUvR8DyM+jrIrrlYJEkCNeRcHHx8ZgRINogSa6j3DD0jyaCu9BSrM4jlL6Y6P19yHJE67DN/1u5CJ+06ISJfaFAf+N7DAb90CgoyYPnkKhvF5eSuat3w25X5miVocnPw0bw26LCQ+IJ5F9uMQ==|tkp:BFBMksy2suhh
PFA:
Jeep Wrangler JL Power/Pressure washers 1680458983603
Pig-Pen
Banned Camp
2018 JLU
jabroni
When you spend very little you get one that wont work with common accessories. The accessories ive seen are universal in a common size. Home depot sells accessories and if they dont fit you can return them.
i bought one at costco years ago. It started leaking and i wanted to save the hose and wand. They didnt even unscrew! All permanently attached. Had to junk the whole thing.
make sure you buy one with removable hose.
i bought the better electric pw at HF. Its been working great. Works with generic accessories i bought. Not TOO powerful to damage your vehicle. I use it to also power wash backyard furniture, stucco and concrete as well, which is why one attached to the wall wouldnt work for me. And i have HFs extended warranty. Any issues and i walk in/walk out with a new one.
