Coldwater pressure washing after trails?
  1. CapitanBlack
    CapitanBlack Active Member
    Vehicle(s):
    Jeep Wrangler JL Rubicon 2018
    Sep 21, 2018
    Vancouver, B.C., Canada
    36
    Liked:
    Does't really work well... I have no hot water tap at the rinse station in my building. Normal coldwater pressure washing leaves white mud/dust streams and stains when car dries. (mine is black JL )... Pressure washer I use is good - Bosh 1600 psi. Is there any powerful detergent for cold power pressure washing which actually helps?
  2. 47Jeepster
    47Jeepster Well-Known Member
    First Name:
    Tom
    Vehicle(s):
    2018 JLUR: 2018 Grand Cherokee Summit
    Jul 8, 2018
    Queen Creek, Arizona
    414
    Liked:
    377
    Occupation:
    You might find a lead in this video:
    I haven't tried it ... but ...
    I also use a cold water pressure washer after trail rides when mud, cow patties, etc. are involved. Simply try to bring it back to a semblance of "lightly soiled" instead of caked. If we're not going on a trail for a week or so, then I head out to the touch-less car wash down the street. The soap the car wash uses looks somewhat similar to what is in the video, which is why I bookmarked the video for later consideration.
    Oh yes, my Jeep is white, which helps with the illusion of being clean.
    Sidhu and CapitanBlack like this.
  3. OP
    CapitanBlack
    Vehicle(s):
    Sep 21, 2018
    36
    Liked:
    yeah.. I got a similar foam cannon together with my Bosh pressure washer too - mine has a smaller bottle but that's OK for one Jeep. Now trying to find a detergent which works is the best with cold water :D
    3Y33Wt87TpnzJec_8Cdp-HuNzhX0bD2rlnYnnOsutRWL_1OmshbMMx2iGGVLK9C_MhYe86MIbv3bQa5Mw=w2601-h1950-no.jpg
    Quest likes this.
  4. TXRubicon
    TXRubicon Well-Known Member
    Vehicle(s):
    '18 Firecracker Red JLUR, '18 Porsche 718 Cayman
    Nov 8, 2017
    Houston
    336
    Liked:
    512
    I use Chemical Guys wash with their foam cannon with cold water and it works great. It goes on a lot thicker than seen here but this was after a couple minute soak. Have been using foam cannons for over a decade and won’t go back. Depending on the level of soil though you are going to have to scrub. Take a microfiber mitt with you to agitate the stubborn dirt.
  5. AnthemAVM
    AnthemAVM Well-Known Member
    Vehicle(s):
    Jeep JL
    Apr 29, 2018
    92646
    245
    Liked:
    153
    Which chemical guy soap are you using? Will use mine for the first time today.
  6. BWWJL
    BWWJL Well-Known Member
    Vehicle(s):
    18 JLU Sport S
    Apr 25, 2018
    Chicago Area
    688
    Liked:
    459
    Garage Profiles:
    Curious, what are the cables for?
  7. Ron_H
    Ron_H Well-Known Member
    First Name:
    Ron
    Vehicle(s):
    2018 Wrangler JLU Sahara in Punk'n Metallic
    May 3, 2018
    British Columbia
    198
    Liked:
    131
    Occupation:
    Retired and spending the kid's inheritance
    They go by several names; Windshield Bush Guards, Limb Risers and more. Their purpose is to raise limbs up and over your Jeep, or simply push them asides, rather than allow them to impact your windshield.
    Here's a link to more info on them.
    https://www.morris4x4center.com/blog/jeep-limb-risers-explained/
    wolfdog and Voodoobadger like this.
  8. OP
    CapitanBlack
    Vehicle(s):
    Sep 21, 2018
    36
    Liked:
  9. 47Jeepster
    First Name:
    Tom
    Vehicle(s):
    Jul 8, 2018
    414
    Liked:
    377
    Occupation:
    #9 Nov 11, 2018
    Finally broke down and tried a foam cannon. First cannon, as the Brits would say, went tits up right out of the box. Amazon took it back with no hesitation, so I ordered the one in the above video at half the price of the first one. The MATCC foam cannon worked well.
    Power washed the thick crud off the Jeep first. Then poured 900 ml of water and 100ml of Mequiar's soap into the canister, played with the controls, and used up the full 1000ml while circling the Jeep 1+ times. Put extra foam in the difficult to wash areas - the front/rear ends and on the wheels. JK Gear & Gadgets filled the canister with 100% soap, where I used the instructions from the first cannon and used a 10% solution of soap. Didn't achieve a whipped cream layer of foam ... mine looked more like @TXRubicon 's picture above. However, the results were quite good. When the Jeep was toweled dry, the towels stayed clean! Took one hour to complete ... set up the power washer, wash the crud off the Jeep, spray the Jeep with foam, let it soak, rinse the Jeep down, put the equipment away, help the missus finish drying the exterior, and then cleaning the interior. Cheated a little on the time 'cuz while I put the equipment away, the missus wiped the Jeep dry ... then we both cleaned the interior. That's less time than I spend hosing the crud off beforehand, drive to-and-from and using the local car wash.
    I'm sold ...
    Oh yes, a side question: Remember the "Whipped Cream" album cover for Herb Albert and the Tijuana Brass? Did that come to mind while you were covering your Jeep with foam?
  10. Jaddie
    Jaddie Active Member
    First Name:
    Jaddie
    Vehicle(s):
    2012 Honda Odyssey
    Nov 2, 2018
    Buford, GA
    Liked:
    Meguiar's Hyper Wash, Chemical Guys' Honeydew Snow Foam, Optimum Car Wash, and BLACKFIRE Car Wash are all excellent in a foam cannon.
    The foam cannon is fun, but you can skip it with a cold-water rinse if you want to save time. The purpose of the foam is to give you a head start on breaking the dirt loose from the clearcoat.
    I have three foam cannons and have been foaming since December of 2011. I know nothing about Jeeps, other than I want one, but I know a good bit about detailing.
    thundermuffin likes this.
  11. Jondrew
    Jondrew Well-Known Member
    First Name:
    Bob
    Vehicle(s):
    2018 Rubicon
    Dec 3, 2018
    Central Fl
    865
    Liked:
    846
    So I’m not the only one old enough to remember that album
    47Jeepster likes this.
  12. Lorris007
    Lorris007 New Member
    First Name:
    Lorris
    Vehicle(s):
    Land Rover
    Dec 18, 2019
    England, UK
    Liked:
    There is no detergent that would change the situation very much if the there is no enought pressure from the machi. I suggest you not playing with the chemicals and buy a stronger pressure washer. Sell your`s may be someone would buy it. Better read this to choose a good one www.propressurewasher.com
  13. MacJack
    MacJack Well-Known Member
    First Name:
    O)|||||(O Jack
    Vehicle(s):
    2018 Rubicon JL 2 Door
    Aug 9, 2018
    Western NC
    407
    Liked:
    217
    Garage Profiles:
  14. Lorris007
    First Name:
    Lorris
    Vehicle(s):
    Land Rover
    Dec 18, 2019
    England, UK
    Liked:
    #14 Feb 22, 2020 at 12:36 PM
    Hi there. You can actually find this information easily on the internet, you just have to search for it. By the way, I am using the cleaning services like this one leedswindowcleaningservices pretty often, and I can say that these guys are doing their job very well. I don't know what detergent are they using, but it's very efficient. Thanks to this thing, everything that they are cleaning is looking like new. I have ordered their services several times and I was always satisfied with their job.
  15. Redbaron73
    Redbaron73 Well-Known Member
    First Name:
    Ronnie
    Vehicle(s):
    2020 sport s unlimited;2020 Rubicon Unlimited
    Oct 1, 2019
    53
    Liked:
    Useless comment
    Karl_in_Chicago likes this.
Loading...
Share This Page
