Offroad Head-Snap/Body Roll
yokramer
Snark Incarnate
I believe you answered your own question. 3.45s, a 2.72:1 case and 5.13 first gear is already not much of a crawl ratio. Wheeling obstacles in 3rd gear means you are going too fast.
Rocksports are also pretty soft and they don't control big body motions that well.
Yea that 48.14 crawl ratio compared to my Auto Rubicons 77.24 is going to be a big factor in speed
yokramer
Snark Incarnate
JT1
Broken Arrow, OK
2021 Willys Gladiator
And that's in first.. OP mentions keeping it in 3rd..
I wheel with a bunch of autos.. 1st gear always over the obstacle, shift to 2nd/3rd to catch back up, back to 1st for the next obstacle.
I'm on 37's with 5.13s in a 6spd, but I don't ever NEED to hit the gas to crawl up or over anything.
JEEP4U
Richard
2021 Jeep Wrangler
Rockgardens in 3rd gear.....Thats funny.
Jeep Wrangler JL Offroad Head-Snap/Body Roll 1687893632463
How? 6speed Rubi with 4.88s is 100.137
5.38 gears
Gorilla57
Chandler AZ
2019 JLUR Mojito
I should have mentioned I have the 6 speed MT. Seems tricky to 2-foot drive without being able to feather the clutch or am I missing something?
You should be in 1st or 2nd gear. Then you can lightly hold the brake and not stall it. I learned to wheel in an 85 Toy 4Runner, with the 5spd and a Marlin 4.7:1 t-case. 2 footed it all the time and yes it would stall every once in a while. But you will learn when to let up a little on the brake/give it a little more throttle and it will keep going. Takes time and practice.
mtbjeep
mtbjeep
MA
2018 JLUS
I have 4:56 gears
RubiSc0tt
Upstate NY
2019 JLUR in Punk'n Orange
Turn Wrenches/ Write code
Is this your first Jeep?
Have you ever done any off roading before?
serious questions not meant to shame or belittle.
It sounds like you need to learn to drive Manual transmission off road. Very similar to how I started out. I started out with a 98 TJ sport: 4.0L, manual transmission, transfer case low range in first gear is 2.72:1, axles were 3:73, with 33” tires. Lots of clutch dumps and stuff when rock crawling.
Learn how to use the clutch, where the engagement/ disengagement point is; only depress the clutch there to fully stop the Jeep.
Use your manual transmission like a gear selector. Don’t shift like you do on the street. First gear is crawl, second gear is general trail, third gear and up is flat ground, dirt roads, sand, etc. Put the transmission into the right gear before the obstacle. If you have to shift midway, it’s going to require some learning of clutch finesse. It’s tough to describe.
Additionally, your body positioning is key. You want your butt/back against the seat as much as possible when driving, unless trying to see over the hood. Hands on the wheel and/ or gearshift, don’t hook your thumbs. Use your arms to stabilize a bit. heels planted on the floor, feet firmly on the clutch/ throttle/ brake. You might have to side foot the right foot a bit. It’s almost like riding a mountain bike or motocross bike. You need to prep your body to take the impact and sort of flow with it. Hope this makes sense, because I don’t think I’ve ever typed it out before.
mtbjeep
mtbjeep
MA
2018 JLUS
I wonder if this is possible with the sahara transfer case, 35's and 4.56 gears. I an heading out Thursday and will try this approach. All the big obstacles are primarily in 1st gear, I don't spend the entire day in 3rd obviously.
JT1
Broken Arrow, OK
Mine is a 2.72:1 case. Mine will actually walk right up waterfalls. I can even hit the brakes and drag it down to about 500rpm and not stall it.
mtbjeep
mtbjeep
MA
2018 JLUS
Thanks for the response. 51 years of age, manual driver my whole life. First jeep. Started off-roading this year. The manual certainly makes it more interesting!
mtbjeep
mtbjeep
MA
2018 JLUS
Wow. I guess it's decades of feeling the slow speed in the seat of your pants and seeing the low revs that makes my MT brain unhappy.
mtbjeep
mtbjeep
MA
2018 JLUS
You will need more tire and suitable shocks. If you are top heavy........a Hellwig rear sway bar will also help.
When you say more suitable shock could you please expand your thinking? I currently have MC rock sports.
