Noisy driveshaft
Roky
Roky
Does anyone out there hear the rear driveshaft clunking when going on a trail at low speed (10-20 mph) mostly when you let off the gas and then back on the gas? Not a constant noise, more intermittent. Is this normal or should I bring it to the shop?
DaltonGang
Doesn't Play Well With Others
You might get those U-Joints checked out. Could be nothing, could be something.
spurly
Zach
Nebraska
2019 Bright White JLUR
Could just be the backlash in the ring and pinion, but I don't think it would be loud enough for you to hear it.
American Jeeper
Jeremy
Kansas
2019 JLUR
Software & cloud services
It shouldn’t do what you are describing I wouldn’t think. I know the driveshaft boot can get nicked and have seen several torn on JK’s after trail runs. They make a lot of noise and vibrate when that though. Make sure you didn’t knock a weight off. If there is no obvious damage (which is on you), then I would make sure it’s nice and clean and take it to the dealer.
Jeep Wrangler JL Noisy driveshaft 8F8E96F5-7E9E-4253-8D0A-E0795DF4A6EB
spurly
Zach
Nebraska
Of course, I was under there checking everything out making sure everything’s tight, had shop re tighten all lift components, when I turn the driveshaft with my hand back and forth that little bit of turn makes the exact same noise I hear on the trail. I just don’t know what the tolerance is supposed to be for that.
That's the backlash between the ring and pinion. The driveshaft shouldn't rotate back and forth more than 1/4 inch at most and you definitely shouldn't be able to hear it making any significant noise.
EugeneTheJeep
Fred
Us
Jeep
I’m having the same issue. Did you find a solution?
Billet_JLU
Austin
Ohio
2018 JLU sport s 1999 Cherokee Sport
Mechanical Engineer
Could be slop in the driveline. I have a 6 speed and in 4 low if theirs still a load on the drive train when I push the clutch in it makes a lot of noise.
Roky
Roky
Roky
That was in my Sahara, and it end up being the knock in the rear differential that everyone’s having issues with. There’s a thread on it in here somewhere.
Amby94
Amber
ag05142011
2018 Jeep Wrangler Unlimited Sport JL
Did you ever find out what was causing this noise? My dealer said wait till it gets worse. They won’t cover under warranty because they don’t know where this noise is coming from.
entropy
Foothills of the San Gabriels
OF top 1% content creator
Do you have the LSD package?
Roky
Roky
Roky
Toxiclows
Christopher
2020 Willy’s jl
Suspect
Franky
South Florida
2015 JKR
I’m having the same issue and it’s driving me crazy. Dealer hasn’t been able to get to the bottom of it and just gave up and told me to kick rocks until it gets worse. Something is definitely wrong with these Dana 44s, it’s not just the LSD that suffers from it my rubi has it too.
I was really hoping to find the solution in this thread :(
