New Raptor Load Range C 37s?
jerseymike
Allentown, NJ
2018 Wrangler JL Unlimited Sport S
Yes it is crazy, those 37s way almost exactly what my 315/70/17s weigh
cball508
2022 Wrangler 392
I wasn't able to get the tire weight separately, but my setup (AEV Borahs, KO2s, protection ring) came in at 100 lbs total today. I'm happy with that 👍
Mattyp1214
Black 2018 JLUR
I'll be a little more than that but on beadlocks
RubiRed
Richie
WA
JLR, Odyssey, S2000, 911
Here are the 37" KO2 Load C mounted! On Quadratec Recon wheels. They're pretty much the same offset/backspace specs as the Mopar accessory wheels.
Jeep Wrangler JL New Raptor Load Range C 37s? EFC9C410-E7E2-4C79-A1C2-8F666B28E760
Jeep Wrangler JL New Raptor Load Range C 37s? C91CCA5B-DFAC-4F50-89BA-569C5C4D6AD5
Jeep Wrangler JL New Raptor Load Range C 37s? BD75E24C-24F0-4230-BA94-454AF45CF0C0
Jeep Wrangler JL New Raptor Load Range C 37s? 9B6FB107-98CF-4C4D-92AC-D2DFDBF0DCE6
On the Discount Tire lift so I guess this is what a 3" lift might look like?
Jeep Wrangler JL New Raptor Load Range C 37s? 4EB7C2D0-FD49-4C18-9E7D-C78550A36C62
My trusty helper doing the chalk test. I got down to 24 psi and the edges are almost even. I don't think I'm going to drop any lower for now. Maybe my 2 door is just lighter. I think most 37" owners report between 25 - 30 psi. At 24 psi I'm seeing a height of 35-3/8". So basically these are legit 36" tires. If they just marketed as such I think everyone would be happy. :giggle: That's the sweet spot for me.
Jeep Wrangler JL New Raptor Load Range C 37s? DD354BD0-91F0-4059-96D5-2300F5A940ED
Jeep Wrangler JL New Raptor Load Range C 37s? 21C3BF53-3B9C-4751-A41B-709579EEFF70
Smoke ‘Em
Tyler
KS, CO
2019 Wrangler JLR
RubiRed, that is GORGEOUS! Are you running any sort of lift or is that bone stock aside from tires/wheels?
alksion
Josiah
Brea, CA
21 Rubicon 392, 21 Sahara Altitude
Biz Owner
Jeep Wrangler JL New Raptor Load Range C 37s? BA44F62D-5CD8-4FAE-8BB3-2DD643A356BB
View attachment 473434 View attachment 473435
View attachment 473439 View attachment 473440
At 24 psi I'm seeing a height of 35-3/8". So basically these are legit 36" tires. If they just marketed as such I think everyone would need happy. :giggle: That's the sweet spot for me.
What were you running before and how is the road noise and handling? Any major differences?
4xFUN
Scottsdale AZ
2020 2-door Rubi. 2023 RAM TRX
Perfect size for us cool kids with 2-door JL's :) My 37" C's are here but I am in middle of installing a Dana 4.88 UD44 front axle / regear rear axle and will not have a chance to finish till this weekend...I can't wait to get these monsters mounted!
RubiRed
Richie
WA
Thanks Smoke 'Em! I was pretty much bone stock 2 door Rubicon with factory suspension and 285 KO2. Mainly added metal bumpers and winch, see everything in my signature. I've barely driven 10 miles on them so no deep insights. But let's be honest it's not going to be much different than the smaller KO2 I came from. With the taller sidewalls to absorb things it does feel more plush going over speedbumps. I haven't taken hard turns yet but I imagine the tradeoff is slightly more roll in corners.
Two things I was certain would follow...but now I'm slowing down to reconsider. I thought I would immediately regear from factory 4.10 to either 4.88 or 5.13. I also thought I would immediately put a 2" spacer lift (thinking AEV). After just minimal time with it I no longer feel they're imminently required.
  • I have a 6-speed. It definitely felt sluggish from the moment I left the tire shop. But even after a couple short errands I've adjusted my shift points where it's kind of passable. Of course nothing I can do about the start-from-standstill in first gear. I'm going to run it a bit before making a decision. I still feel regearing will eventually happen, just not sure I need to rush into it.
  • To satisfy my curiosity I took my stock Rubicon suspension out to get flexed. The front driver is pressed against the bump stop here. The front driver tire barely meets the inner fender. The rear passenger tire however does slightly press on a couple spots of the fender. My take: I'd be okay rock crawling with this light contact. But I would be worried doing high-speed dessert run as the sudden smashing when bottoming out could knock the fenders out. I'm still leaning to a small spacer lift but again it seems less urgent than I expected. It really surprised me it took on this much flex and almost got away with no rubbing. Note YMMV - I'm on 2 door Rubicon V6. Just about every trim level/engine/number of doors has different suspension setup or final ride height.
Jeep Wrangler JL New Raptor Load Range C 37s? IMG_1920
Jeep Wrangler JL New Raptor Load Range C 37s? IMG_1921
Jeep Wrangler JL New Raptor Load Range C 37s? IMG_1915
richsteele
Rich
2019 OB JLR
Looks good! Almost like a stock CJ7 on 33s.
gato
New England
2021 JLUR
My first two tires arrived Monday and my remaining two tires arrived today. Brought a bathroom scale to weigh two of them. 65.4 lbs and 64.2 lbs. So the average is right around the advertised 64.8 lbs BFGoodrich claims. I'm happy with that :like:
It's insane to have a 37" tire at under 65 lbs, even if they are a bit smaller. If they prove durable and puncture resistant on the trails, it will be a great option for many.
It's also sad that Jeep does not offer anything bigger than 33s on the Wrangler, while Ford is pushing the tire manufacturers to hit their weight goals, with 35s available in every Bronco as an option, 37s on the Raptor and likely the Warthog Bronco. At 65lbs the fuel mileage hit is much, much less significant than what the 392 costs them.
alksion
Josiah
Brea, CA
Biz Owner
Agreed. I want to put these one my 392 as soon as I get it. Sounds like I will need a bit of lift to avoid rubbing off roading though.
