Guv
2018 Wrangler Sport 2.0 E-Torque 2 Door
Well, they added a spark plug check to the PDIs and there's the bulletin about them. The one we had came in with a dead miss on cylinder 3. Pulled the plug and the diode was smashed in enough to give zero gap. Luckily the plug didn't break or it would've required an engine replacement per the bulletin.
I'll laugh my ass off if they had the pre and main chamber plugs backward from the get-go and all the engines out there are backwards.
How would this happen? The plugs use different size sockets. Aren’t the plugs installed by robotics on the assembly lines?
alphawolff
california
2021 JLU
They were in the right spots, but it's possible the right spots are actually backwards on the engineering side.
Think about how that one nasa rover crashed because one of the suppliers used imperial units instead of metric. That kind of mistake.
It's probably some other issue but it'd be super funny if this was the problem
croppz
Zach
North Carolina
2021 JLU Rubicon 2.0T
People can’t even change their oil correctly or on time for that matter and they want people to worry about changing double the spark plugs lmao
Guv
Agreed, that could be a career move for someone.
Or possibly, sabotage by the 007 of the Bronco underground😳
roaniecowpony
Retired Engineer
So you are saying the engineers are fallible
Jeep Wrangler JL New Jeep 2.0T Hurricane 4 has complex tech [Engineering Explained] {filename}
Probably those software engineers. I mean software changes are the solution to everything, so that must be the cause too.
croppz
Zach
North Carolina
You know. It wouldn’t fuckin surprise me if they were like “yeah so change intervals are 30k miles for the small plugs and 60 for the big plugs”. It would be the most stellantis move ever and I wouldn’t even bat an eye at the retardation
yokramer
Snark Incarnate
I do like how many people are freaking out over this yet having 2 plugs a cylinder isnt a new thing. Sure its not common but its not like there isnt a history of it.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
That'd really throw "a wrench" in it, since, of course, they're the same size!
croppz
Zach
North Carolina
Not new tech but also completely unneeded in something like this lol
gek
Code Monkey
The regular engineers apparently couldn't figure out how to fix their terrible clutch (couldn't figure out how to add a steering stabilizer) so they had to have the software engineers do it, and we've all seen how that panned out.
At least they seem to have stopped exploding.
Guv
But they require a different size socket. How is an assembly line robot going to get that wrong?
roaniecowpony
Retired Engineer
The robot has to find that spark plug socket in the bottom of the tool bag first.
Guv
Heimkehr
Pennsylvania
2021 JLU 2.0T
What's the octane specification for the new GMET4 Evo? Just wondering if the engine's functioning, to include the risk of plug damage as first mentioned on p. 9 of the thread, can be cross walked to the grade of fuel being used.
Ratbert
PNW
Software Engineer
We can utterly trash these engines by putting the spark plug in the wrong place (see previously posted dire warnings about making sure it's correct), but potentially also by simply using insufficient octane?
