Need help! Lift questions
Heather
Southern California
2018 Jeep Wrangler Jl unlimited S
I really don't want to lift my JL and have to get new wheels and tires, plus lose even more mpg. I've seen some people post about spacers and I'm curious to know what it does. Does it give a lifted appearance? Does it affect off roading and function? Help! Opinions please. I offroad my Jeep but it's also my daily driver so I need opinions.
Roky
Roky
Yes you can use coil spacers, it will raise it some, it just depends on how much you want. There’s several spacer kits available, just do a search and you’ll probably get to many choices. :).
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
It's hard to "appear" lifted without taller tires and a coil spring spacer lift would allow the clearance for that. It will work but no where near as functional as spring and shock real lift kit.
If your referring to a wheel spacer, yeah, it will only push the wheel outward.
lightsout
PNW
Les Schwab has a 2" spacer lift installed for $425 should be one close to your in So Cal, they will also do the alignment if needed.
Heatherreanneee
Heather
Southern California
I don't want much! Just a tad bit. Thank you so much!
Heatherreanneee
Heather
Southern California
Hmm... Definitely something to think about.
