TTEChris
- Chris
- May 17, 2017
- Houston, TX
- Website
- www.tankcustoms.com
- 2021 JTD & 2021 4XE
- Vehicle Showcase
- 5
Did the expert you trust sell you on the 4 wheel alignment? Only reason I ask is without adjustable arms/trackbars etc there is absolutley nothing they can adjust in the rear. In the front they can only adjust the toe(and center the steering wheel), but in my experience unless it was off from the factory it doesn't change much with that small of a lift.Hey Carlton,
Steering doesn’t feel too loose. I had a 4 wheel alignment from an expert here that I trust. He corrected as much as he could but showed me how the spacer lifts on the JL still create a little angle to the right. It came out to .108 degrees overall and it’s in the rear only but I don’t feel like that’s what I’m feeling. .108 is basically nothing.
I think what I’m feeling is normal for 35” tires and no upgrades steering stabilizer....I hope haha.
Steering stabilizers are a very easy DIY project if they bolt in the factory location. The ones that go over the tie rod require you to remove the trackbar bolt (21mm socket) and replace it with a new stud. That can be more difficult if you don't have the right tools and a torque wrench.
