ColoradoMike
Denver
2022 JLUR XR
The world does not need another Hell's Gate video; there are many. But, this was MY first attempt at the Gate, so I made a movie. Hey, nobody says you have to watch it! :D
P.S.: the first person to tell me not to stand up in the saddle will be summarily ignored!
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Great video! And no, I hadn't seen anyone comment on how challenging it is to get down to the bottom.
I've done Hell's Revenge a few times, but I've never had full combo of spotter, capable rig, and balls. Unfortunately my last run was solo.
p.s. don't stand up in the saddle! ;)
Opus
Midwest US
www.jlwranglerforums.com
Hey, if you're willing to run Hell's Revenge you can do the Hokey-Pokey in the saddle if that helps! :)
GrumpyOldVet
Missouri
'24 JLURX, '21 Chevy Tahoe RST, '21 HD FLTRK
I'd say that was more than attempt!! Great video too! That's for sharing.
Gorilla57
Chandler AZ
2019 JLUR Mojito
You can ignore me all you want, but this is just plain dumb. No seatbelt on an obstacle that is known to roll people very badly is not something you should post. Plus you are holding onto your roof rack support, a likely spot to be crushed when you roll.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Great video! I say keep making videos of hells gate! You actually made that look easy! Great job!
I think I would be nervous standing up like that though, not sure if the weight could shift and work against you.
Jeep Wrangler JL My first attempt at Hell's Gate teno44411r
Beau Nugget
Bruce
NE Kansas
2019 JLUR, 2013 JKUR, 1979 Jeep CJ7, 1975 Bronco
Well done! And great video. Thanks for sharing. I don’t blame you for standing up to see a little better
Barchetta
Max
Franklin NC
24 JLRX Firecracker 3.6L; (sold) 02 TJ Sahara 2DR
Off road noob here...completely stock Rubi XR? Which engine? Tell us what other config settings you used (Sway bar, lockers, what air pressure did you air down to, did you use select speed control while standing etc.)
ColoradoMike
ColoradoMike
Denver
2022 JLUR XR
That descent has a couple of big, off-camber, tippy steps near the top. I had walked it a couple of times and never liked it. It's STEEP. I don't know why people don't talk about it/show it.
ColoradoMike
ColoradoMike
Denver
2022 JLUR XR
That's a mostly-stock Rubicon Xtreme Recon. I have added an engine/oil pan skid plate and ARB diff covers, totally unnecessary for this obstacle. 3.6L etorque. Sway bar disconnected, of course; Essential for articulation. Rear locker engaged, though probably not needed. Front locker not engaged; not needed at least in a Rubi, and engaging the front locker can make quick steering adjustments tough. That's what I would fear most here. Tires are the XR's stock 35-inch KO2s, deflated to 15 PSI. Plenty sufficient for this obstacle--though I have found other spots in Moab where beadlock tires, down to 8 PSI, would be much more effective. I failed to clear the final ledge on the Chute on Flat Iron Mesa two days later because my tires just wouldn't hook up. 37-inch beadlocks at 8 PSI would have made it a breeze. No, hell no, regarding select speed control. Ever. I am controlling the throttle. I am standing on my left foot while working throttle with my right. You should never do this. As others said, keep your seatbelt on and hands inside the Jeep. Always. Only I should do this. ;) LOL.
ColoradoMike
ColoradoMike
Denver
2022 JLUR XR
I was just there last month. You’re right. Nobody talks about the way down. I didn’t do it. I got too scared. Great job making it all the way.
I was there like six times over the course of 2.5 years before I finally felt good about doing it.
LKG
Larry
Boise, ID
23 JLUR (soon), Gen 2 Cummins, 22 Sport Alt. R.I.P
Well, I watched and enjoyed it, nice work! As much as I hate to admit it, 25 yo me would have tried that in a second but 50 something me has gotten, well lets say, less adventurous, damn it.
AVGeek99
Peyton, CO
2025 JLUR '41, 2024 Rubicon 4xe (wife's) Bright White
I've run Hell's Revenge one itme. I hooked up with a few guys from PA at the dinosaur tracks near the beginning. They were in a JKUS and a YJ. The YJ driver spotted the JKUS and I down into Hell's Gate and back up the other side. He, understandably, wasn't comfortable attempting it with his short wheel base.
For a first timer especially the route down was just as, or maybe more, intimidating that than going up.
The spotter I had was great. I had no issues going down or up. It really seemed pretty simple. We've all seen a hundred videos of people making Hell's Gate look really hard. The key is to stay on both walls and stay as level as possible. Never let either side get too deep into the V or you'll slide off the wall, which will make things much more difficult.
