Metalcloak lock-n-load vs Game changer
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Here's a rate calculator: https://eibach.com/us/p-192-spring-rate-calculator.html
For some reason I thought @Headbarcode had shared a pic of the 4.5s, and I ran that data (and that from my 3.5s) on the calculator using the wire diameters from the MC site at some point a few months back. I'll have to look for it.
I have pics with measurements of both the 3.5" and 4.5" rear springs laying loose on the ground next to each other. I forgot to do the same with the fronts, as far as free length measurements, as I was starting to run out of daylight.
I also have pics with measurements of the front 3.5's and 4.5's installed at normal ride height.
I'll gladly post them if they are of any interest to you or anyone else.
The relatively short compressed length is offset by an approximately (IIRC) 3" upper bracket, and about 1.5" from the lower outboards.
6 Pak spec:
  • Compressed Size Eye to Eye: 13 1/4"
  • Extended Length Eye to Eye: 28 1/4"
With 4.5" of bracket "shock extensions":
  • Compressed Size Eye to Eye: 17 3/4"
  • Extended Length Eye to Eye: 32 3/4"
The front upper relocation brackets are specifically for the 6-packs. The front lower relocation brackets are meant for the Rocksports or any other comparable long travel shocks. They both should not be used together.
I have a brand new set of front lower relocation brackets, that only spent about an hour on my Jeep. The droop was amazing, but I could nearly remove the 3.5" springs without having to first remove the bumpstop spacers. ?
Headbarcode
LI, New York
:rock: ……..
Jeep Wrangler JL Metalcloak lock-n-load vs Game changer BoldEnragedIguanodon-size_restricted
Exactly where I got the idea.
Back when I found out that the no limits front links were too short for my setup, even when fully extended, I also found out that my rear sway bar was hitting the bottom of the frame on both sides. Another one of their videos was part reason for starting me on the road to the front and rear Antirocks, which eventually fixed both issues.
Headbarcode
LI, New York
Are your pats the original mt01s or the new mt02s? Wife was happy with the 38" mt01s on the last jeep, I'm trying to find someone whose run both to see if there's a noticeable difference. The difference in wire diameter is pretty minimal, so the spring rates wouldn't be far off. I still don't know why everyone doesn't post their rates. If they are worried about other companies copying them, spring testers are cheap especially if you're getting into the manufacturing business. It's not some top secret proprietary information.
Specifically mt01 or mt02 are not on my sidewalls. I did see these, on the 38's and 40's respectively...
Jeep Wrangler JL Metalcloak lock-n-load vs Game changer 20230309_155526
Jeep Wrangler JL Metalcloak lock-n-load vs Game changer 20230309_155826
Those center of the pic numbers end in 01 and 02. Is that it?
Zandcwhite
Zach
Patterson, ca
2019 jlur
I don't think there was a 01 on the original version, but the 02 should be evident.
Jeep Wrangler JL Metalcloak lock-n-load vs Game changer Screenshot_20230310_105149_Chrom
fasteddie760
fasteddie760
Ed
SOCAL
2019 JLU
I just ordered the MT-02 37s this morning. Northridge 4x4 is having a buy 4 get 1 sale on them.
Headbarcode
LI, New York
Oh, that much of an in the face marking. That's not on my 38’s and 40's, so both sets are the original versions. I've had the 40’s since Nov 2021, so the 02's are a more recent release.
Zandcwhite
Zach
Patterson, ca
2019 jlur
They say "all new", but they look the same to me. At least the OP can give us a review, but I don't know if he has experience with the originals for a direct comparison?
Headbarcode
LI, New York
I like them, but I liked them more when they were under $300 a pop. I won't be going with a 3rd set. Nothing else in this size range was readily available at the time, which is why I bought the 2nd set.
Zandcwhite
Zach
Patterson, ca
2019 jlur
We liked them in the 38x13.50's, but aside from super heavy nittos there's not much else available in that size. Tempted to try the kanati mud hogs in a 39 when it's time for tires.
Headbarcode
LI, New York
Yeah, more manufacturers should get into the 38 game. I came across the Mickey Thompson XS's in the 38x13.5 size, but went back to looking after finding out they are bias ply and directional.
Long story short, and eventually figuring I'd see how the Jeep did with 40's, I got my eye on the Mickey Thompson Baja Boss M/T's. They seem to get rave reviews in the rain and snow, all while having a higher tread wear rating than the Pat's.
fasteddie760
fasteddie760
Ed
SOCAL
2019 JLU
I paid $331 each for the 37s. Nothing else comes close to this price.
I've never tried them before, I'm more of a BF Goodrich guy.
Ed
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Yep, all the M/T02s are clearly marked M/T 02. If they don't have that on them, they are the first gen M/T 01s.
There are a lot of changes. I had a long chat with our Milestar rep a few days back, these are my notes:
There are quite a few changes between the MT01 and the MT02.
The three big changes:
  • Carcass
    • Better quality fibers.
    • Changed the angle of the plies and how they lay.
  • Extra material under the tread area
    • Gives the tread blocks more stability.
  • New compound
    • More silica - Helps cold and wet weather performance
    • That was all they could really tell me about the compound. The rest is formulation changes and that's like the Coca-Cola secret recipe.
Cosmetically, there few changes. Mostly to sidewall patterns and not in all the sizes.
The benefits noticed during testing:
  • Better performance at a higher pressure. Testers were finding that if they were running 8psi on a certain trail, they could get the same performance or better at 10-12psi.
  • Better tread performance on road in cold and wet conditions.
  • Longer rotation intervals. Instead of 2500 to 3000 mile rotations, they're now seeing 4-7K miles rotations (depending on application).
Milestar says these changes are evolutionary, after seeing how their tires perform and talking with the people out there running them.
I have ran 35" Patagonias in both the first gen M/T 01s and the M/T 02s (prototypes) on my JK. The MT02s were noticeably better on road, less tread squirm and they worked better off road. I wouldn't say better by a huge margin, but they were improved.
Tread wear was also improved. But you still gotta keep them inflated enough to run them on the crown.
word302
Oregon
JLU
Doesn’t everything have a higher tread wear rating than the Pats??
