dlong1119
- Dan
- May 13, 2021
- Gainesville, FL
- 21 Sahara 4xe (StingGray)
- Vehicle Showcase
- 2
Incorrect. Wheel offset is absolutely tied to the wheel width when determining where the front and rear edges of the rim will be. Offset refers to where the mounting surface is in relation to the center line of the rim, positive means its closer to the front and negative means its towards the back. Without knowing the width of the wheel in question there is no way to know where either front or back edges will be. Backspacing will give you the back edge measurement by itself.No, your thinking backspacing not offset. With offset the width of the wheel isn't relevant. ... at least not if a wider tire isn't required. Of course, if you change the tire width half of the difference will go to either side of the new rim.
run some examples here:
https://tiresize.com/wheel-offset-calculator/
This is a better and easier calculator to use when fitting wheels, assuming you know the dimensions of what you're starting with.
http://marksink.com/tire_wheel_offset/offset.html
The SRT wheels, when compared to the stock wheels on my wife's Sahara 4xe (20x8, et45), will extend 30mm more into the wheelwell, and 20mm more towards the outside of the fender. Not much poke for him, but 30mm inboard is quite a bit and would likely rub on the control arms when turning.
