Lower Control Arm bolts.
Sqwkvfr
Minneapolis
2021 JLUR
So I’m in the process of trying to install the lca from my mopar lift. How did you all get the factory bolts out? Breaker bars. Electric 700lb/ft rated impact. 1/2 air impact. These F@&%€ won’t budge. Anyone got method to remove?
Warz2k4
RIC
New York
n/a
I got a makita impact 1/2 driver ..."nut busting 700ft lbs of torque" , came out EZ.
BuffaloBill
WI
2024 Wrangler 2.0, 2020 wrangler 3.0
My M18 Milwaukee impact did the job removing. I did the final tightening with torque wrench, placing foot against Jeep and pulling hard.
Roky
Roky
This......but be careful and hold on tight...:)
Jeep Wrangler JL Lower Control Arm bolts. 35D7355E-613B-4EAC-9A7A-629A9F6AF51E
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Electric impact to get off.
Sphincter muscle to get back on and torqued.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
You’re on the ground, right? Floor jack on the breaker bar (carefully)
gato
New England
2021 JLUR
Breaker bar against the floor on one side, breaker bar with floor jack on the other.
I found out using the 700 ftlbs breakway rated impact on only one side did not work. Those bolts need to be held on the other side to come out.
Torquing them back up was easy since I have long torque wrenches - again had the other side wedged against the floor with a breaker bar while torquing.
But yeah, took some trial and error.
multicam
Tanner
Alaska
2018 4Runner, 2019 JLR
No one mentioned PB blaster?! Soak dat shit!
letsassume
Columbus, OH
2020 JL Sport
Milwaukee M18 here. Honestly I was looking for an excuse to buy it, and a control arm swap was it for me lol. Had them off pretty quick, but I ended up having to hold the nut with an adjustable wrench because I didn’t have the right socket. Whoops.
Jolly’s Jp
NC
2021 JLUR on 37s
My impact (700 ft-lbs) Wouldn‘t break the nut loose but when I held the nut with a wrench and put the impact on the bolt, it came right off.
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
Some Random Guy
Washington
Comptroller
I did something similar when torquing. Box wrench and wedged a chock block so it was pushing against something rubber and removable, not stuck torqued into my garage floor.
Kraty1
Batavia IL
2018 Jeep Wrangler Unlimited JL
Sales & Marketing
I made the mistake of doing my LCA’s without any power tools… purchased an impact immediately after. 140ft/lbs is no joke in either direction, and PB blast was a must
Punkindug
Doug
Albany, NY
2021 Rubi 392
Ok so if I get them off and install the new ones what is the proper ft/lbs to torque them to? I think I read somewhere a while back "as tight as you can get them" on the JL. is that 140 ft/lbs?
