Long start this morning
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Hey everyone. Had something weird happen this morning that never happened before
started the truck and it took longer to start. Almost like when I replaced the fuel filter /water separator and it cranks a few times
I turned it off and started it again.
Anyone run into this ?
Punkn89
Alex
Maryland
2019 Wrangler
I dunno! I just pray to sweet, little baby Jesus that it even starts. Also, (sorry if I sound like a dick here) please don’t call a Jeep Wrangler a truck šŸ˜‚.
Punkn89
Alex
Maryland
2019 Wrangler
That's significantly better than calling it a car.
On one of my wranglers registration, it was classified as a convertible. I don't remember which year that was.
munkeymike
Tx
What do you call it then? An SUV? For some reason that feels even more wrong.
I just call it a Jeep.
Punkn89
Alex
Maryland
2019 Wrangler
Yes, Jeep works, let’s go with that.
BDinTX
Dallas, Tx
I've not experienced that yet. If the second attempt was normal crank time it would seem less likely to be a battery issue but I'd probably check the voltage on it anyway. Sounds like a fuel problem... : ( good luck
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
I call mine a truck all the time...My JLURD identifies as a truck and I don't want to disrespect.
alphawolff
california
2021 JLU
Technically it is an SUV. It's the original SUV.
I just call them jeeps. It's the only jeep that's actually a jeep still being manufactured. Everything else is just fluff
Hard Rock Jeep
Richard
Nashville
2016 JKUR HR, 2022 JLUR 2.0, 2022 JLUR Diesel
The proper name of a Wrangler and its forefathers is Jeep. It can also be referred to as a vehicle. It is not a car or truck. A JT may properly be called a truck or Jeep, but not a car. A Bronco is not a Jeep.
BDinTX
Dallas, Tx
Diesel owners should be more helpful to each other. There's only about 7 of us left.
For the rest that are sharing their profound thoughts on what it should be called, I think the point has been made.
Jeep Wrangler JL Long start this morning beat a dead horse
ALeeL
Anthony
2021 JLURD
OP, check or replace you fuel filter to verify it isn't clogged or leaking causing the system to loose pressure. I would start there. It could also be a faulty fuel return valve.
AC77
AC77
AC Abegian
Los Angeles
Thanks for the reply, i replaced the fuel filter 4 months ago, i replaced it at every other oil change , the fuel pump recall was also done in January. I think my Banks Derringer may be the culprit,, but cant verify it
miner3649er
Colleyville, TX
2021 Wrangler Rubicon 4 Door Eco Diesel
I had that same issue when I replaced the fuel filter and mine persisted slightly for a couple starts. If it feels the same as when you replaced your fuel filter I’d say look at the fuel supply system or, as you thought, the electronics that regulate the fuel supply. If you didn’t torque the fuel filter it could be that even though it’s been 4 months. Those O-rings need to be lubricated with diesel before you install the fuel filter or it can stick, be up to torque spec and act like it’s sealed up but leak later. Check under the Jeep to see if any diesel has dripped. Same song different verse with the oil filter. Lubricate the O-rings.
