WXman
- Mar 1, 2017
- Central Kentucky
- 2018 Wrangler Unlimited
- Occupation
- Meteorology and Transportation
Yes, TFL is testing at high elevation, but I'm personally at 500-800 ft. elevation when I drive around here and I've seen the exact same results. My diesel Jeeps of the past would average 23-26 MPG unloaded, but throw a trailer on and they'd fall to 14-15 MPG rapidly. On the flip side, my gas engines, whether V6 or V8, would only start out around 15-19 MPG unloaded but would only fall to 12-15 MPG while towing. There is a HUGE loss with diesel, or with any other powertrain that's high efficiency. Even electric vehicles like Teslas consume FAR more energy and lose range exponentially faster when worked hard. That's just how it is.This is a load and elevation dependent phenomenon. How often are you comparing V6 gas to V6 diesel towing the same load with the same vehicle at elevation...or even at sea level? I can tell you from personal experience and that of many others that apples to apples, diesel loses less under load most of the time. Believe what you want, but low end torque moves loads and diesel has 15% more energy by volume to start with. FWIW, I’ll have a very direct 3.6 to 3.0 JLUR mpg comparison for you in short order...same roads, same loads.
Large tires are similar to towing...they add load against the powertrain. All I'm saying is, if a guy buys the diesel because he assumes that 37" tires will cause it to lose less MPG, that guy is going to be sorely upset at the results.
