Spotted 2 JL and a JT EcoDiesel testing in Moab
JLURD
Alaska
2018 Compass Latitude 6MT, 2020 JLUR 3.0
I’d love to know what that ridiculous fluid line under the DEF tank is for. Clearly not part of the production spec given prior images of the 3.0 and haphazard temporary attachment, but they’re certainly asking for it to be crushed if they were doing any serious wheeling in Moab.
OilBurnerHoldOut
Richard
Big Spring, Kentucky
07 Ford Edge, 76 Yamaha xs 500. Formerly-79 cj5.
UPS Worldport 1DA
Really hoping the eco diesel debutes at sema or the LA auto show. Ya know, since we can't get a cummins.
evo8904
Tampa
2017 Ram/ Wrangler soon
God I wish that I had that job. Testing out new vehicles would be amazing.
leanxormean_stack
Ali
WA
2019 JLU
Software Eng.
Well. The RAM 1500 including the Rebel is now out with EcoDiesel. How much harder is it to get the JL to pass same bar to make it in production?
Cypher
J
AZ
2020 Jeep Wrangler Unlimited Rubicon
Cybersecurity Leader
The ram also has the 3.6 BSG and that will not be offered on a Rubicon or sport. My guess is that the packaging and usage is very much different between the other vehicles and the wrangler. Trying to keep it reliable and tough enough for a wrangler to be trail rated probably is part of the issue.
JLURD
Alaska
Gen3 3.0 ED 1500 has not been EPA/CARB certified yet so not sure what you mean by “now out”. They’re no more out than the JLUs.
wrangler-rob
Robert
New Jersey
That hose as someone already mentioned is probably for DEF fluid and hopefully only a temp prototype solution. Either that or Jeep has fully embraced the culture and making it easier for people to DELETE the DEF/DPMF etc.... :) I know I'd be working on that almost straight away if it were me with a diesel. I could almost see it already, insert TAZER, disable Regen, disable DPF filter check, disable DEF fluid check, insert new Catback exhaust, change the "pee" tank into a pressurized water source. Enjoy a ridiculously powerful, efficient, (hopefully) longer life engine.
SnowDog
Paul
Denver
Employee: Boss, we need to do "vibration testing."
Boss: There's a dirt road about 2 miles away that's got a really bad washboard thing going on.
Employee: Boss, I meant "slick rock testing" so we have to go to Moab.
Boss: Ok, have fun.
JLURD
Alaska
I’m thinking the DEF tank will be converted to an auxiliary fuel tank quite often...assuming it isn’t cutting into the departure angle and getting whacked by rocks all the time as some suspect.
JLURD
Alaska
Definitely aux fuel tank.
It would definitely be nice to wire up a small transfer pump to one of the Aux switches on the dash and watch the looks on people’s faces when you fill the DEF tank with diesel.
Jim Marsh Chrysler Jeep
