Iggy
Well, it seems you are quite clear about what you really want. Sounds like you should adopt a older Jeep and start tearing it apart. Have fun!1) True, but I don't usually resale cars. I drive them until I'm done then donate to the Purple Heart Foundation...at least 3 of my last 4 vehicles.
2) The Atlas II bolt on for JL with 4.3:1 is surprisingly not that expensive
3) Electronic swaybar can only be run under certain conditions and speeds, I would prefer manual control, and if it's dark and muddy, I just run without a sway bar.
4) Yes, but the Dana 30 is WAY under rated and I'd prefer stronger model like a Dynatrac or Currie down the road.
5) yeah, but only 1.5 inches, which will be largely made up for after aftermarket rims
6) Will be doing a lift anyway so kind of a non issue.
7) See 6.
8) Only locks in 4Hi and under 20mph and will disengage automatically, that's kind of BS if you ask me.
9) Again, only locks in 4Lo...see the BS comment above.
10) Will be replaced with 4.56 at a minimum anyway, so not worried.
11) That might be nice.
12) Already seen some Rubicon rock sliders that damaged the rockers, and I already have the last set of JCR Classic sliders for a 2dr sitting in my garage.
13) Yeah, I'm more of a ground clearance than high fender kind of guy. Both my YJ and XJ ran on almost 7" of lift.
14) Again, the 8.4 would be nice, but honestly I've been running off a small cell phone screen for years, so even the 7" w/ Android Auto is going to be a huge step up.
15) If I stay with my original order that was apparently not actually cancelled, it's more like $9k before interest. That 9k could get me the Currie HP D44 and the Atlas II t-case.
And I get where you're going, the problem I have with the Rubicon is an extension of the issue I have with the JL/JK. I really don't like all the computer controlled crap on it. I want to be able to physically manage the mechanics of my vehicle, like lockers, sway bars, whether or not the vehicle stops and starts. I wish they'd just go back to the inline 6 4.0 and leave a good thing be. You want more power, drop in an LS1. But the eco-Nazis and over reaching regulations have put an end to that, sadly.
Or, there is what appears to be a really nice '01 XJ down in Houston I may have to go check out if it's not already sold.
