Jtphoto
- Jeff
- Dec 10, 2017
- Thunder Bay ON
- 2022 Rubicon Xtreme Recon Granite Crystal
Going through the same.
I sat down with the dealer tech/trans specialist and this is how it works.
- the tech does the initial inspection and reports finds ie codes, symptoms etc. to Stellantis warranty department before transmission is even opened up ( no sense wasting time opening it up without parts on hand).
- Stellantis makes the decision to order TCM/Valve body combo before transmission is opened up. (TCM - transmission Control Module and valve body are together inside the transmission).
- If the transmission is found to have excess shavings, burnt oil, parts on the magnet etc when the tech opens it up they will then authorize a new transmission.
-If everything looks good they will change the TCM/Valve body.
- if that does not fix the issue a complete transmission and torque converter will then be ordered.
If the transmission is noticeably slipping then that is the clutchs which the valve body/TCM swap cannot fix. Hence they went right to new trans.
