JL - Trailer Brake Controller
digitalbliss
North Alabama
2018 JLUR, 1979 CJ7
I just don't want to go the route of switching wires, diode/no diode etc on this rig. As painful as it is, I'm gonna wait for the MOPAR OEM controller to be released for the JL's.
Ya go jacking around with electronics on these new rigs and end up frying something, you'd really be pissed.
You're not jacking with the electronics on the rig. You're swapping a couple of the pins on the plug that connects the brake controller to the factory plug. It's really not rocket science. But I do think the MOPAR option looks nice.
uawho
Nate
Arizona
'20 JLUR Hella Yella
Civil engineer
I completely agree
Yet, have you read the entire thread :whew:
If you need to tow now, what would your plan be?
Appears to me that many folks have done all of the footwork and discovered the best route to go, at this point and time
I just haven't seen any conformation that the 3073 triggers the trailer brake lights when the boost is initiated :movember:
IrnBear
We are doing a camping/hiking weekend this Saturday and I'll have a chance to test out the Redarc "manual activation" button. I'll report here if it lights up the trailer tails or not.
CRZYCDN
Matthew
St-Lazare
2024 JL XR Unlimited
Its a small diode in-line, I belive its on the red wire. You should see some extra shrink tubing under the back mesh on the red wire.
uawho
Nate
Arizona
Civil engineer
Agreed.
I cut off that plastic adapter at the right (the one you're hand is touching), and reconnected the one that came with the Redarc. Color to color. So the diode is still inline, between where you cut and the Mopar plastic lighter grey adapter.
No IFS
So Cal
JL Rubicon
ordered the Mopar trailer brake controller for my JL. I'll post install pics when I get it
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
Who did you order it through??
Abramovich
Arizona
2021 Sport S (Chief) and 2022 Willys XR (Gobi) ord
That's still a preorder, right? I don't think they are in stock anywhere yet.
No IFS
So Cal
JL Rubicon
Ordered through vendor sponsor here. . Yes it's a pre-order
Altitude2020
Canada
2020 Jeep Wrangler JLU Altitude
I got my Mopar brake controller October 29th. I was on a waiting list number 278 and it took 2 weeks to get.
traviswalker007
Tony T Walker
Phoenix, AZ
2018 JLU Rubicon
I have the Tekonsha 3073 p in my JL and everything works but the elctric brake??? I got lights, turns, hazards but just 2 little lights on the tekonsha Primus Iq? I tried the other pigtail and everything worked fine except when you hit the boost the dash goes ape shit. I also blew a 30amp fuse hooking this pigtail up not sure what the issue is but when I boost it nothing, no lights no numbers
CRZYCDN
Matthew
St-Lazare
I belive it should be the 3073 ..not the 3037 (as you mentioned)..?
CRZYCDN
Matthew
St-Lazare
Did you modify the wires/harness? Do you have the factory tow package? Wondering if the controller is bad?
traviswalker007
Tony T Walker
Phoenix, AZ
2018 JLU Rubicon
factory tow, It is suposed to be plug and play but no brakes, and controller says not connected cant figure it out.
