JL - Trailer Brake Controller
Halstem1
Alaska
Hi Everyone, not to beat the "dead horse"... just confirming ... I have a 2018 JLUR with tow package, if I purchase this cable and controller, its all plug and play with no other issues or activities that need to be done?
Really appreciate the feedback, trying to get things ordered/set for the road trip in a couple days.
My jeep did not come with the trailer tow package from factory, so my setup is different than others. I installed the mopar wiring harness after purchase. I did not have a way to tie into the brake wire without splicing wires. The connector cable that Wibornz references did not work on my setup. I ended up using a wireless controller and so far, I'm very happy. Good luck.
CRZYCDN
Matthew
St-Lazare
2024 JL XR Unlimited
I called the customer support for Reese....the main company makes all 3 brands, Draw tite, Reese and Tekonsha.
Reese 8508211 and Drawtite 5535 are the "Same" just different label on the front (says their Technical support)
As well I also found out that 3014 works but doesn't have the Diode (so don't use it!) 3073 is the correct pin-out with Diode (Correct for Wrangler) or use 3024 (Also has diode and is for the Ram) but just swap the black and blue wire on the grey connector end for the Wrangler.
mergedown
Jason
Columbus, OH
2018 JLU Sahara
Same, I tried for a long time to get a wired trailer brake to work for those of us that did not get the OEM tow package. I gave up and purchased the wireless controller. Just towed my Jayco Hummingbird for 12 hours using it and it worked great!
Jeep’n Jay
Jay
Salt Lake City
2018 JLU Sport
I have been using the bluetooth controller made by Curt. It is freaking great! Have towed over 8k miles with it so far.
iba56978
'18 JLU Sport S
Agree, the Curt Echo is fantastic. I was concerned about issues with Android Auto but it works flawlessly at the same time the phone is running GPS and Pandora through Android Auto.
I had a few instances where it would drop the bluetooth connection but that seems to have gone away.
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
It is plug and play. It take less than 10 minutes to install it. I have over 10,000 miles of trouble free towing with it on the road and trail. Just returned from a 5734 mile trip and towed the camper.
uawho
Nate
Arizona
'20 JLUR Hella Yella
Civil engineer
I just read through this thread yesterday, and finally jumped in.
Just bought the Redarc Tow-pro. I love the ability to hide the controller and just see the small knob on the dash somewhere. My JLUR has the tow package, so I'm not expecting any complications other than placement running the wires.
My teardrop is finally going to be ready by the end of the month, so I have some time to get it installed and looking good.
Jeep Wrangler JL JL - Trailer Brake Controller 1596654201097
JoBuck
Jodie
Corpus Christi, Texas
2020 JLUWD Sarge Green
2020 Willys without the factory tow package. Installed the Red Arc Tow Pro Elite and tapped into my third brake light to trigger the controller. Towed 500 miles this past weekend and absolutely no problems
Reddysk1
Siva
2019 Rubicon
I'm getting my trailer next week so i'm curious what you ended up installing? I have the factory tow package
CRZYCDN
Matthew
St-Lazare
I installed the Drawtite 5535 and 3073 cable. Worked perfectly...! Simple plug and play...hardest/longest part was to finally decide on location to mount it on the panel below the steering wheel.
I used small bolts/washer with nylock nuts...as the little screws that come with it/combined with the thin plastic panel wasn't confident it would stay secure.
I ziptied the slack cable up on the metal braces right under that panel/above the pedals.
Only thing I want to do now is either paint the bolt/washer black to help hide them...or get black ones.... I know being picky now!!
uawho
Nate
Arizona
Civil engineer
I finally got the controller installed Its been so dang hot, its hard to go work on the Jeep in the garage.
While I was in there, I added a dead pedal too. Been wanting to do that for a while now.
Jeep Wrangler JL JL - Trailer Brake Controller 20200829_163212
beaups
Sean
Ohio
2020 JL
How the hell do you press the clutch with that thing there?
uawho
Nate
Arizona
Civil engineer
Lol.
I installed this really cool add on. It changes the gears for you. So I took my clutch pedal out completely. Its is so effortless, it's almost "automatic". In fact that would be a good name for it. Maybe I could get a trademark for that name.
