JL Compatible Hard Top Lift
LHB
south shore, MA
'18 JLU, Rivian R1S, '99 Cherokee XJ
Does anyone know if there is a compatible lift on the market? Looks like most should work...not sure if anyone has tested any.
Thanks!
TXRubicon
Houston
'25 Rubicon X, '23 Porsche Cayman GTS, '23 Grand Cherokee Overland
I know the rear hook on the Lange Hoist-A-Top JK one probably will not work on the JL due to the way the rear of the hardtop is with the spoiler. It's bolted in so it can likely be modified and replaced fairly easily but don't know that there's enough of them out there for anyone to have done it yet. A four strap system would work though.
Magnetdragon
Erwin
Tampa
Jlu!!
I just ordered my Toplift Pros cart. They made some modifications to fit the JL but the newer version will also work with a JK. I don’t have a tall enough garage to do a hoist and my wife can easily lift her top off as well with this.
Topliftpros.com
Rubi-Zero
Nashville, TN
JL Rubicon , Audi S5
it’s funny when people say they don’t have a tall enough garage for a hoist system. If you can pull your Jeep into the garage, it’s tall enough to lift the top off with a hoist or even ratcheting straps
Magnetdragon
Erwin
Tampa
Jlu!!
Lol well I also have a tear drop trailer in the garage so it doesn't fit with the hardtop hoist
wanderer
Ralph
Carlsbad CA
Engineering Geologist
you can build one your self it is easy
Rahneld
Ronald
Boston
JL Wrangler
Thanks!
@LHB: I'm going to assume you seek a product that the manufacturer has rated and tested with the JL.
Alien Technologies' Top Lift Pro https://www.topliftpros.com/ and the Freedom Jack JL or the FJ3 (two different JL products from the Freedom Jack, LLC.) https://www.freedom-jack.com/ both come to mind and I know work well.
TJEli
Eli
MI
Jeep, truck, car
I installed the Lange basic a couple weeks ago. They supply a new bracket now for the rear of the JL. Works great. $150.
-Eli
