Installing Factory Alpine Sub in a Base Model
akm313
AK
Buffalo, NY
2021 Willys Unlimited
Has anyone taken a factory Alpine subwoofer and successfully installed it in a base model? Not the PSS-23WRA
I originally got the 7” basic sound system (no subwoofer at all) then recently upgraded the radio to the 8.4” Uconnect and it sounds so much better already. I wanted to kick it up a notch so I found the whole Alpine factory rear panel subwoofer at a local junk yard and looking to install it. I read through multiple threads and can’t find anyone who did it. Can someone guide me? I’m still new to these forums
Gaust
Todd
Portland, Oregon
2018 Wrangler JLU Rubicon, 2018 Renegade Trailhawk
You’d have to use an aftermarket LOC or dsp and an amplifier to hook the subwoofer up to. From what I understand there’s no subwoofer output or amplifier, from the factory radio, unless you have the Alpine system installed.
akm313
akm313
AK
Buffalo, NY
I think I’m just gonna take it to a professional to install. I don’t know anything about audio systems.
ModMike
Quebec
2020 Jeep JL Willy’s
That is correct. Doing an upgrade on sons 3 month old Willys and you need an LOC and amp to make that work.
akm313
akm313
AK
Buffalo, NY
Do you know how big of an amp the factory subwoofer can handle?
AusJeepNoob
Sydney, Australia
2020 JL Wrangler Unlimited - Rubicon EcoDiesel
The factory amp is 46W per channel with 4 separate voice coils so a 4 channel amp that makes 50W per channel into 2Ohms should be enough. I wouldn't put much more than that through it.
akm313
akm313
AK
Buffalo, NY
Nice thanks for that info. That helps a lot! Do you by chance know how many watts are going to the subwoofer or how many watts the subwoofer can handle? Also is the subwoofer single or dual coil?
Vandy23
Craig
Jersey
18 JlU Sahara
The stock sub is a quad voice coil. With the current stock Alpine set up it’s getting slightly less then 200 watts rms. Not sure what the peak ratings are. I have taken mine apart and the quality is not bad but you certainly can do better aftermarket without breaking the bank while still using the enclosure.
akm313
akm313
AK
Buffalo, NY
Perfect thanks for the info! This helps a lot!
akm313
akm313
AK
Buffalo, NY
So does that mean each speaker and each tweeter can handle 50 watts each? If im asking a stupid question I apologize. I know absolutely nothing about sound systems
AusJeepNoob
Sydney, Australia
The factory premium audio amp is claimed to produce 46W per channel so technically they should be able to handle it. I haven't tested the output of the amp so don't know how accurate the claim is. The speakers in the premium system are also 2Ohm rather than 4Ohm that most aftermarket speakers are. It means that if you replace the factory speakers and retain the amp you will have less power driving them or if you replace the factory amp but retain the speakers you need to make sure that the amp is capable of driving a 2Ohm load.
LSguy
Ohio
2021 Willys
He does not have the factory amp.
OP, get an LC2I Pro and an amp. And grab an aftermarket sub. See if the guys installing your new sub can seal that sub box up for you. IF you want to spend a little bit of money, the JL 10tw3 is a great sub that they could make fit in that hole. If you go that route, grab a kicker CXA800.1 amp. Get the sub in dual 4 ohm, wire to 2 ohm. That'll be 600 watts rms off the amp, which is plenty of overhead and will allow gains to be kept low. This setup would sound amazing if installs done right, and parts price for everything will be ~$700. It can be done cheaper if you wish to give up bass and sound quality. That factory sub is junk honestly. Grab your signal from the sound bar wiring and run it into the lci2 for processing.
Crusifix
West Virginia
2019 JLU Rubicon 2.0T Hurricane
Silly question, but maybe not. I am looking to beef up the inside of my stock Aline sub's plastic surround with resin and overlay that with a "dynamat" material. I will be upgrading the sub and adding an amp and 2-channel LOC. Can I grab the signal from the original sub harness, or is the soundbar still the preferred source to take the signal from.
Thanks!
-Jeff
