matrix311
You can get them in various offset. I got mine in -12mm.I just got the same wheels in. Looks great but I think they are 3.5 BS
is this spare on the stock tailgate setup?Are those the 5-127 bolt pattern?
SST Pros on Methods? Looks great man.Man I mounted a tire on my wheel and slid it in place to check to see how they will fit. The stick out pretty far! these wheels have a 3.5" BS. What do you guys think will I have problems with this setup? The stick out like 3.5"
Yea Method BeadlocksSST Pros on Methods? Looks great man.
If you’re good with how far they stick out, go for it! Do you have laws (enforced) in your area about tires sticking past fenders?
You’ll get more mud/rocks kicked up from the front tires going along the sides to the back - so consider a protective film (especially for the hinges).
How does it clear the front bumper and fenders?Man I mounted a tire on my wheel and slid it in place to check to see how they will fit. The stick out pretty far! these wheels have a 3.5" BS. What do you guys think will I have problems with this setup? The stick out like 3.5"
that looks great, what size rims i see the back space what is it -12 offset?Clear fine now that I have the lift on
Did you have to use a spare tire relo?We have method racing mr312 17x9 wheels wrapped in nitto ridge grapplers 35x12.5R/17. The wheels are -12mm (4.5") backspacing on stock height Rubicon and fit perfect. Not to aggressive sticking out and they clear when the wheel is fully clocked left or right. So far no rubbing that I can see but I have not fork lifted it yet to max flex it out from all sides.
Thanks! Ordering now.Yes, that should put them out almost 2.8" and leave you lots of room inside.
