Ideal offset/backspacing JL
boogie
kelly
jeep jl
Man I mounted a tire on my wheel and slid it in place to check to see how they will fit. The stick out pretty far! these wheels have a 3.5" BS. What do you guys think will I have problems with this setup? The stick out like 3.5"
aug0211
Ohio
JLUR 4xe
SST Pros on Methods? Looks great man.
If you’re good with how far they stick out, go for it! Do you have laws (enforced) in your area about tires sticking past fenders?
You’ll get more mud/rocks kicked up from the front tires going along the sides to the back - so consider a protective film (especially for the hinges).
boogie
kelly
jeep jl
Yea Method Beadlocks
mtomac
Michigan
2018 Wrangler Unlimited JL - 2017 Silverado 3500 Duramax - 17 Chevy Equinox
How does it clear the front bumper and fenders?
boogie
kelly
jeep jl
Clear fine now that I have the lift on
boogie
kelly
jeep jl
thanks -44mm/3.5 they stick out there for sure lol
jhawklive
South Carolina
2018 Jeep Wrangler JL Rubicon
We have method racing mr312 17x9 wheels wrapped in nitto ridge grapplers 35x12.5R/17. The wheels are -12mm (4.5") backspacing on stock height Rubicon and fit perfect. Not to aggressive sticking out and they clear when the wheel is fully clocked left or right. So far no rubbing that I can see but I have not fork lifted it yet to max flex it out from all sides.
Did you have to use a spare tire relo?
MarcRRT
Marc
ATX
2018 JL Rubicon
Respiratory Therapist
Going with Fuel Beast D564 17x9 5x127 bolt pattern with -12mm offset and 4.5” backspacing. Tires are Falken WildPeak A/T3W 35/12.50R17 121R. This will be for a JL 2 door Rubicon with RC budget spacer lift. Will this work? Thanks.
FrankieFJL
Frank
Massachusetts
2018 JL Rubicon
IT Professional
Yes, that should put them out almost 2.8" and leave you lots of room inside.
