How to remove stickers on soft top window
Lonewolf62
Edward
Gallatin, TN 37066
2022 JL Rubicon V-6
Anyone have a way to safely remove stickers from a soft top window? Friend has a 2021 JLR.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Safely? No.
You can try standard sticker removal techniques but it is very easy to damage the soft window in the process. I wouldn't even attempt it unless I hated the sticker so much that window damage would be preferable.
If you do attempt it, try Automotive Goo Gone, WD40, or 3M Adhesive Remover. Maybe light heat from a hair dryer but not so much as to weaken the soft window. Try to lift it up with a soft edge, like a credit card. Proceed very slowly and carefully.
Lonewolf62
Lonewolf62
Edward
Gallatin, TN 37066
2022 JL Rubicon V-6
Ok, I have goo gone and wd at home. I will tell him what you said!
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
I took a dealer sticker off my rear window with no damage but it was a pain. I used WD40 and just kept rubbing it with a towel until all of the glue was gone
Bill_P
Bill
Orange Va
WOW why would a dealer do this, how horrible.
I know. Fuckers put it right on the window. They also put a dealer badge on the back after I told them I didn't want one.
Kryten
US
2023 Wrangler Rubicon Unlimited
Hit it with a hair dryer or a heat gun. Just don’t go too hot with a heat gun. This will soften the adhesive and make it easier to peel the sticker. Then use goo-gone or a similar product to remove any adhesive left behind.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
They probably didn't tell the lot tech preparing the car and they are told they have to do it to all vehicles, still not an excuse when you told them not to.
Luckily when I picked mine up all they did was put a license plate frame on and a duck on the dashboard when we were signing paperwork.
Vito92
Isaiah
Detroit
2022 Wrangler JL 2Door Willys
Second everyone suggesting googone and wd40. I prefer googone I recommend removing in a cool shady spot. I used googone to remove a stripe off my old nissan cube and it worked pretty well
Stengaaa
NJ
Chevy sonic, soon wrangler Jl 2 door
Any chance since you told them you didn’t want it they get you a replacement window?
Pinky Tuscadero
Kenosha Wi
2021 Pink RHD Wrangler 2015 RHD Wrangler
A few beers and your fingernail with patience and even then probably start looking for a sticker you actually like as removing one from clear plastic that's been baking in the sun..... probably leaving some sort of mar to cover up regardless..... ugh !!! ?
If using any of the above chemicals test a very, very small spot as those ideas are generally for glass, bumpers, bodies, and hard plastics... not soft flex clear plastic.... but, who knows ?
Bill_P
Bill
Orange Va
It was a used car so I doubt it. There was no damage other than my utter rage at having to spend over an hour getting all the gunk off my window. When I looked at it on the lot, no sticker, said I didn't want anything on it, when it came out of detailing there was the sticker and dealer badge :mad:
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
Just an FYI on goo gone, as others have said, test carefully.
I just used goo gone on my f150 where a previous owner had 3M VHB taped side window visors on. and goo gone got on my rubber weather stripping around the windows and it definitely caused it to swell a little wherever the drips stayed on it.
