High stock suspension?
AmericanEric
Eric
Murrieta, CA
2020 Jeep Wrangler JL
Hey guys, so I’ve heard people say the JL diesel is higher stock than a stock gas version. I have a diesel but don’t have a gas model to compare it to. Anyone know if this is true? Thanks!
hazards280
Midland MI
22' JLUR 392 - Sarge Green
The diesel willys uses rubicon springs and shocks in the front, where the gas variant would only have the rubi shocks. Now, I'm not sure if this translates to a higher ride height since the engine weighs so much more.
I'll try and post up some photos when I get home.
I'll also swing by the dealer and measure the fender height on another willys (gas) to see how it compares to mine.
AmericanEric
Eric
Murrieta, CA
Thanks! I have a Willy’s diesel and was wanting to lift so I could run 35s, but I should be able to run them stock if the diesel willys has the rubicon suspension parts right? :idea:
Gawdly
2020 JLUR 3.0D
JLU Rubicon diesel sits 1.25" taller than JLU Rubicon gas engine in stock form. I've measured. Check out the diesel lift thread on here for measurement photos.
Parratt
Logan
Edmonton Alberta
2020 JLUD, 1988 MJ, 2010 XK (Sold)
My 21 JLU Sahara Diesel on 35" No lift is the same height as my friends 20 Black And Tan with 35" and a 2" AEV lift.
UrbanCowboyAZ
Sean
Scottsdale, AZ
‘20 JLURD, ‘02 TJ
Real Estate
My JLURD has 35x12.5 with no rubbing at full flex or lock. My understanding is that, and it may be offset specific, almost all gasser JLUR’s will rub a bit with 35x12.5 tires, which means it must sit a bit higher. I’ve read 1-1.5” as others above have stated.
Compression-Ignition
Roy
Montana
How big are your 35's? Some run pretty small.
GearWhore
2021 JLUR Diesel, 1972 Arctic Cat Climber, 2006 Triumph Speed Triple
Gentleman Explorer
I measured 39" from ground to outer edge of black Rubicon fender lip at both front and rear with stock wheels/tires/suspension on my 2021 JLURD. Does anyone have or have seen measurements for a 3.6 or 2.0 Rubicon?
kmmn
Martin
Maryland
2021 80th Anniversary EcoDiesel, 2013 JK Sport & 2014 JK Sport
As I'm still deciding what to order, I test drove a Rubicon diesel and 2.0 back to back... The diesel felt higher climbing in and we measured them afterward and the diesel sits about 1.5 inch higher (2.0 was a soft top)
Jacobs69
Eric
2018 Wrangler JLU Sport 2.0L
Any updates on this? Am very curious if a JTRD is taller than a JTR gasser. Could make it 2-3” taller than a base gasser JT.
diamondschwin
Tennessee
2019 Bikini Blue JLUR, 2021 Billet Silver JLURD
Yes the JLURD is taller by about 1.5 inches.
My wife has a stock JLUR 3.6 on 315s and it was about 1.5 inches shorter to the bottom of fender and frame rail than my (at the time) stock JLURD on the stock 33s
Jacobs69
Eric
How interesting! Thanks for this.
zdr
Zach
Central PA
2021 Rubicon V6 6-Speed Manual
I just measured a 21 Rubicon Ecodiesel and compared it to my 21 Rubicon manual V6. Both have the tow package. The diesel has approx. 7,500 miles on it and steel bumpers. Mine has approx. 4,500 miles and the plastic bumpers. The diesel sat approx. 1/2 inch higher at the front fender and approx. 3/4 inch higher at the rear fender when compared to mine (same level ground). I have read that the Ecodiesel Rubicon sits 1.25-1.5 higher than a regular Rubicon. Would the steel bumpers on the diesel cause that much of a difference?
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
Did it have any other pieces of armor (on/under) or a tire carrier on it?
