Hey, another MXT275 install.
gek
Code Monkey
I was looking through this thread at the many installs, and was suffering from a severe case of analysis paralysis on all the locations and different ways I could install this radio when I came across and was inspired by Txcomp in this thread: https://www.jlwranglerforums.com/forum/threads/midland-gmrs-stealth-install.75432/
I decided to get my tape measure and calipers out and design and 3d print a platform for it to mount to. I was feeling real good about my first attempt. I thought I was going to be a 1 and done until I realized I ignored the measurements I wrote down and made the thing .5" to wide.
V1
Jeep Wrangler JL Hey, another MXT275 install. 2023-04-09 22_46_11-Windo
Not to be deterred, I narrowed it, added a cutout for the rear bar and some holes to zip tie it to it then tried again only to realize that it sat too low, and turned upside down put the rear cross bar in the way. (This one does work great for the driver's side)
V2
Jeep Wrangler JL Hey, another MXT275 install. 2023-04-01 20_33_30-Autodesk Fusion 360 (Trial ends in 30 days)
Jeep Wrangler JL Hey, another MXT275 install. 2023-04-09 22_48_45-Windo
With Version 3 decided to move it up, but I only had a little bit of space or it would hit the part of the MXT275 bracket the held the radio in. Once the print was finished I attempted it and the outside ends of the clip snapped off. The bracket moved up and in only allowed one side to flex. It still held great which eventually gave me an idea, but first I had to make a mistake with version 4.
With Version 4 I beefed up the outer edge that had snapped before. It worked great, but the inner part of the clip now broke off. It also still held very well with parts of the clip snapped off. I also noticed that it still was not as high above the carpet as I wanted. On to to v5!
With Version 5 I was studying version 3 and 4 and trying to figure out how to not break the clips. One of the ideas I had was, instead of printing it on it's back with the layer lines running parallel to the bars making it easier to break, to print it standing on it's edge so the layers were perpendicular. In order to print it on end and not need any support material I had to make the holes smaller and fillet the edges. I also realized, after the broken clips still held very well, that I did not need as much of the clip for the clip to work. This allowed me to remove a large portion of the inner clip which in turn allowed me to move the bracket and radio up further.
Version 5
Jeep Wrangler JL Hey, another MXT275 install. 2023-04-09 23_12_28-Window
Jeep Wrangler JL Hey, another MXT275 install. 2023-04-09 23_16_18-Windo
Jeep Wrangler JL Hey, another MXT275 install. 2023-04-09 23_16_25-Windo
That worked how I wanted, so I mounted it in place. I ran the antenna under the carpet and up along the rear tunnel to the rear of the radio, then I got an RJ 45 extension and decide to route it into the center console and up into the back of the cubby under my window controls.
Jeep Wrangler JL Hey, another MXT275 install. 2023-04-09 23_21_03-Windo
All I have left to do is complete the wiring and it is ready for use.
I did add V2 to thingiverse if someone wanted to print this or have someone print it. V2 looked like it would work great under my driver's seat.
Here is the link.
https://www.thingiverse.com/thing:5945683
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Well done!
My MXT-575 is under my driver’s seat sitting on the floor. Would love to suspend it somehow. Unfortunately my CAD skills aren’t there. Maybe I will show this post to my SIL and he can modify your design and print a similar one for me!
gek
gek
Code Monkey
Well done!
I added the other file to that same link. So both of functional versions are there to download.
Brian0128
Annapolis, MD
2019 JLUR, 2018 Toyota TRD PRO
Engineer
I like the setup. Where did you mount your antenna?
gek
gek
Code Monkey
I mounted it between the hood and outer cowl cover. I got the idea from @obwahn in Moab. It was working well for him and I thought I would try it.
Jeep Wrangler JL Hey, another MXT275 install. PXL_20230501_195337046
Trav73
Travis
Washougal, WA
2021 Jeep JLUR
Had a co-worker print this for me, absolutely perfect fit!
V1
V2
Version 5
Here is the link.
Thanks so much for this! I had a coworker print it for me (v5), gave him $20 for his time. He used a heat resistant material, and it turned out perfect. The fit is spot on this is a perfect place to mount my new MXT275. The zip ties are going to be a challenge to zip up, but I don't think it needs them.
  • Love
Reactions: gek
gek
gek
Code Monkey
I am glad it will work for you.
I only used one zip tie in the center and I put it in before I mounted the bracket, then I connected and tightened it from the rear. I had more trouble getting the antenna screwed into the back.
gek
gek
Code Monkey
This is great. Can you show a pic of your handheld mount?
I'm toying with the idea of a 275 but haven't figured out where I want the handheld mounted.
Here is my mount. All RAM mounts except The actual handset holder. I took the one that comes in the box with the 275 and drilled a hole in the back and mounted it to this RAM Mounts track ball with the included bolt.
Jeep Wrangler JL Hey, another MXT275 install. 1684761897077
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
  • Like
Reactions: gek
Trav73
Travis
Washougal, WA
2021 Jeep JLUR
Been using gek's 3D printed under seat mount for over a year now, it's been great! Now I'm trying to figure out a way to get my new Cobra 75 All Road to fit on top of it. I think it would be a clean install to have both radios mounted so I can use the same AUX switch. They will use different antenna, but they will both run to the same location. I've checked and there is plenty of clearance above the Midland mount. I think I can just glue some thick plastic strips or see if my Co-working can modify the .stl file slightly to make room for the four extra mounting points. What do you think?
Jeep Wrangler JL Hey, another MXT275 install. Cobra_Midland
Jeep Wrangler JL Hey, another MXT275 install. Measure1
Jeep Wrangler JL Hey, another MXT275 install. Measure2
Jeep Wrangler JL Hey, another MXT275 install. Midland_Only
gek
gek
Code Monkey
Glad it has been working out for you. You might be able to melt in some threaded inserts into the current one, or have your coworker modify so they can be installed after. Might have to do something to hold the Cobra higher or to recess the nuts from the Midland bracket.
I look forward to see what you come up with.
Trav73
Travis
Washougal, WA
2021 Jeep JLUR
Thanks for the idea, so simple! This should be easy and less than $20 from amazon. I'll post a photo once complete.
Jeep Wrangler JL Hey, another MXT275 install. 1729430995835-x8
Jeep Wrangler JL Hey, another MXT275 install. 1729431025954-6
Trav73
Travis
Washougal, WA
2021 Jeep JLUR
The inserts worked out great! Thanks for the ideas. Drilled them out 3mm and 4mm used my soldering iron to heat and push them in. They aren't going anywhere!
Jeep Wrangler JL Hey, another MXT275 install. 1729913389724-9l
Jeep Wrangler JL Hey, another MXT275 install. 1729913402722-px
Jeep Wrangler JL Hey, another MXT275 install. 1729913419083-52
