Help!! What tires should i get??
Alex | JLU
Alex | JLU
Alejandro
San Diego
2024 Jeep Wrangler Sahara 2.0 Turbo
Bob Ferguson,
Kind of in the same Delima about tires for my just purchased 2022 Unlimited 4x, it has 275/55r/20 BFG Dualers, wanting something more aggressive and wider tread. Looks like I'm going to go with Nitto 305/50/20 recon grapplers, my tire guy and a little research says this would be a good fit with the width of rims we have. Any ideas or thoughts would be appricated.
are you going to lift or keep it stock?
Alex | JLU
Alex | JLU
Alejandro
San Diego
285/70/18 is about 34”. Too much for no lift, and too little for the Mopar lift. It’s also a load range E tire, which will not help with the ride.
With the Mopar lift, if you keep your stock wheels, go with 35x12.50/18s. There are several on the market in load range C, which will give a softer ride than E rated tires.
Thanks!!
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Bob Ferguson,
Kind of in the same Dilemma about tires for my just purchased 2022 Unlimited 4x, it has 275/55r/20 BFG Duelers, wanting something more aggressive and wider tread. Looks like I'm going to go with Nitto 305/50/20 Recon Grapplers, my tire guy and a little research says this would be a good fit with the width of rims we have. Any ideas or thoughts would be appreciated.
They should fit without a lift, but just barely at 33.2". If you go with that tire, make sure you get the 116S, SL rated version. Almost all 305/55R20 tires are load range E and F. Combine that with a 20" wheel and a short sidewall, and you better make appointments with you dentist and kidney doctor.
I don't know if there is a ride height difference between a 4Xe and other non Rubicon Wranglers. You may need a small spring spacer set to give you anther 3/4" - 1". You will know if you get any rubbing when you drive and turn. The quickest way to figure that out is to reverse it and turn the wheel full lock and listen for rubbing.
Since that tire is significantly wider than you current tire, you may find that the spare squishes the bump stops on the tailgate too hard. You can remedy that quickly by using one or two 1/2" grade 8 washers on each stud on the spare tire rack. Take them with you when you get the tires mounted and installed. Don't let the guy us his pocket knife in the tire bay carve off what he thinks is an appropriate amount of bump stop, or use an impact to tighten the lugs and force the tire to squish the bump stops and possibly dent your tailgate.
This is the version you will want. And at only 51 lbs that's very good, especially for a 20" tire.
https://www.tirerack.com/tires/Tire...TcLC7QV-xHNPbStyKqj1-Dae8eyVvxOxT13r0jXvfzfTp
This is a nice option too, at only 50 lbs. I have this tire in a 17" version, and I recommend it.
https://www.tirerack.com/tires/tire...0OCRTTV2&vehicleSearch=false&fromCompare1=yes
The Last Cowboy
San Antonio, TX
2nd 392
Ca
Stock, sorry this old age thing is catching up with me
Huh, what are we taking about ? I, uh, don’t remem, er … awww jeeez
Jeep Wrangler JL Help!! What tires should i get?? E784CD1A-6A4F-433A-AC1C-3589CD5E498F
it has already caught me 😒
Go4Low
Jorel
2020 JLUR
Since you already lied to yourself once, go ahead and get a set of 40s and let the other upgrades follow.
Be kind to yourself 😎
AmericanPatriot100
Kitsap Co
2025 Wrangler Sport JL
Stock 2025 JL Sport 245/75/17 tires fit well into wheel arches.
Jeep Wrangler JL Help!! What tires should i get?? IMG_3558
Rubicon take offs(springs and shocks) 245/75/17 same tires look stupid now lol.
Jeep Wrangler JL Help!! What tires should i get?? IMG_3591
AmericanPatriot100
Kitsap Co
I know that doesn’t help with what tire to get. But maybe it’ll help with what stock tires look like with a decent lift. I’ve been contemplating MT BB AT in a 35. But I’m more of a pizza cutter tire size person myself. I have Dick cepek extreme country 35x12.5x15 on my 97 Silverado. And the 12.5 wide even in that truck are WIDE.
Grayhound
Michigan
Jlurd
I'm in stock rubicon suspension. I went up 1 size in tire and then got a wider tire with a negative offset rim. I'm really happy with the look and performance of this set up.
Jeep Wrangler JL Help!! What tires should i get?? 20250427_120527
