HELP! Steering wheel locked!
SIGP2101
Canada
JL 2021 Rubicon 2.0T
I got these Messages on the dash:
ABS Service anti-lock brake system,
Service Electronic Stability Control,
Autopark Disabled,
Sway Bar Disconect Unavailable.
Steering wheel is hard as hell to steer. Impossible to drive. It happened after 5 tires rotation routine today. Car is not drive-able. Both batteries are topped up after complete disconnect and still same messages and issue. Any ideas?
Thanks!
Jeep Wrangler JL HELP! Steering wheel locked! IMG_1670
Jeep Wrangler JL HELP! Steering wheel locked! IMG_1671
Jeep Wrangler JL HELP! Steering wheel locked! IMG_1672
Jeep Wrangler JL HELP! Steering wheel locked! IMG_1673
MarkM
Fort Collins, CO
2019 JL Sahara 3.6
Project Manager
Are you sure about the batteries? This sounds like the classic failure.
Are you load testing or just seeing 12-13 volts. They can show voltage, but have no real amperage available.
I would suggest letting it sit a bit on a charger and trying again. I was able to get everything to reset that way a couple time before finally doing the AUX Batt delete.
SIGP2101
Canada
You right, I am not sure, I will attach another deep cycle batt today using booster cables and try again. Each battery shows 12.6 and 12.7V respectively and they are four years old, still original. Will try to erase aux as well and go from there...Thanks for the response.
garyji
Gary
Western NC
Are you still on original Batteries on a 21?? Replace them!!
G.
KCSgtMaj
Andy
KC
MY24 Rubicon Unlimited, 3.6L
Retired Marine, Master Plumber
I suggest you go to the gym and work on upper body strength to be able to maneuver your vehicle when the power steering goes out.
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
Blown fuse? Heavy steering likely means the electric PS pump isn't running.
SIGP2101
Canada
Thanks guys, back to normal. New battery, aux bypass, fuse 42 removed. Upon start, same messages, same codes, same impossible steering. Decided to go for a short ride to figure out if I can stil drive it to dealership and how. After 200 meters all back to normal????
DaltonGang
Doesn't Play Well With Others
Yep, Classic stupid little tiny battery issue. They should be used in lawnmowers, not Jeeps.
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
Green star connector behind glove box needs replaced. Same issue I had about a year ago. Part 68321746AA
You wiggle the wires it will be good for a few days or weeks then it happens again. When I took mine out you could see solder joints on the bottom cracked and separating.
