Linda z.
He could not pump it up. He tried various fittings on the mouth of the bottle, none worked. He TOLD me he couldn't do it. That is exactly what happened.I can tell you exactly what happened. He hooked up the coolant pressure tester, pumped it up to 20 psi, and checked for leaks. Nothing leaked. You kept bugging him and he wanted you gone. No leak found, the cap is not testable. Replace the cap if desired.
