Help! Coolant bottle empty again!
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
I had a coolant leak in my Dodge Ram. It turned out to be the heater core. Windows fogged up slightly usually in the mornings and underneath the carpet was soaked. Does the 2.0 have a oil cooler? Like the 3.6
Heater and Evap core leaks are very common on the Ram trucks. The 2.0 oil cooler is nothing like the 3.6.
erjdrvr
Indy
Raptor Gen3, 2024 - 392 On Order, Red w/ Winch
Is the turbo water cooled on the 2.0?
Spartan99
US
2008 JKUX
Sounds like a warranty issue to me. I completely understand the anxiety from buying a car and then experiencing problems but I think this could be handled by a dealership under warranty and then it’s smooth sailing from there. Whatever the problem is you were smart enough to catch it before the warranty ran out so it sounds golden to me. I wouldn’t worry at all. I think you’ll be fine in the end. Shit happens with cars it’ll all work out.
Spartan99
US
2008 JKUX
If it makes you feel any better, I was in a similar boat about a year ago and I’m so glad I stuck with it and got it fixed. The vehicle I purchased is perfect now. It’s not a Jeep, but I completely understand how you’re feeling and I think you’ll be fine with that warranty.
DaltonGang
Doesn't Play Well With Others
On something like this, possibly a big issue, I would go straight to the dealership. Stop screwing around, with small time mechanics. Just pay for a diagnosis, if it is warranty covered, then you will owe nothing, and possibly get a loaner car.
Heimkehr
Pennsylvania
2021 JLU 2.0T
The 2.0T has a liquid intercooler. The exhaust manifold is also liquid-cooled. The latter contributes to the vehicle's HVAC putting out warm air very quickly on cold mornings.
mwilk012
Oklahoma
Service
The turbo is directly cooled by coolant.
Rodeoflyer
Bert
Conifer, Colorado
I would fill it up and burp the system(?). Leave the rad cap off and run it up to temp, then refill.
EchoVictor
Raul
Ca
Unlimited Rubicon 4xe
I have a 4xe that was losing coolant. No leaks on the ground just a smell of coolant in the engine bay after running the engine for awhile. I eventually found some coolant coming out of the bottom of the black coolant bottle by the turbo. It’s happening because the coolant is getting hot and burning out of the pressure valve. When I first took it into the dealer they said there were no leaks and it held pressure. After some time it got worse and the next time it went in it needed a new engine.
Jeepjoy
Jason
SF Bay Area
2024 JL wrangler rubicon
So Saturday has come and passed. Was there an outcome to this? Hopefully this isn't an OP gets it fixed and is never seen again.
Jamrock
Jamaica
Suzuki
How bad did it get? Did the engine start overheating at some point? Did you ever feel the a/c stop cooling properly?
