Front axle truss options
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
Just throwing this out there since I was curious. Here are the options I could find for front axle trusses (not including C gussets). Looks like they need ~2” of lift and the usual additional bump stop spacing to keep these from hitting frame or oil pan, etc.
Don’t see any available from Motobilt, Cavfab at the moment…
Artec - ~1/8” designed for strength and light weight:
Jeep Wrangler JL Front axle truss options IMG_3010
Barnes4WD - $80 3/16” says ~2” lift. Bridge over FAD
Jeep Wrangler JL Front axle truss options IMG_3013
Rustys - $179 3/16”. collar under center axle tube, no lift description
Jeep Wrangler JL Front axle truss options IMG_3014
TMR customs - $119 3/16”. Says 1.5” lift
Jeep Wrangler JL Front axle truss options IMG_3016
EVO - $169. I believe 1/4” (description is for C gussets.. full kit says 3/16 for gussets and 1/4” for truss). Hoop goes over diff, does not specify clearance.
Jeep Wrangler JL Front axle truss options IMG_3017
CarbonSteel
I have the full Artec set front and rear (trusses, gussets, and skids).
Don't let the lightweight design fool anyone...the shape when welded in is as strong if not stronger than thicker designs.
Mx5red
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
Seem to be the go-to… which is why I looked if anybody else was even making them.
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
I’m running an Evo front truss but artec is what the shop that did mine installs the most.
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I also have the Artec truss front and rear. For the same reasons.
fat_head
2018 JLU
I welded the Barnes front truss on mine and ran into the clearance issue (because I didn't read the instructions lol) If I could do it again, I like that Rustys truss because of its low profile, although I'd put a couple drain holes along the bottom edge.
Mx5red
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
I like how the Barnes bridges over the FAD, what kind of clearance issue? Frame, oil pan? What bump stop?
fat_head
2018 JLU
Jeep Wrangler JL Front axle truss options IMG_6917
Jeep Wrangler JL Front axle truss options IMG_6916
The top of the truss was making contact with the frame of the Jeep. Had to install bump stop extensions. Also, the barnes truss only crosses/bridges the FAD on one side (front side). I added a piece of steel to bridge it and tie it all together on the back side. That clearance problem I don't think I would have had with that lower profie truss.
Mx5red
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
Thanks - Rusty’s definitely looks appreciably lower… actually they all angle down and look lower lateral to the UCA bracket compared to the more square Barnes?
Roky
Roky
Late to the party, but here’s some pics of Artec…..I just wanted the fad reinforced, so I didn’t do under spring perch, or Cs ……
Jeep Wrangler JL Front axle truss options 23A373CC-7C21-448A-8FA5-AE87ABCFADFC
Jeep Wrangler JL Front axle truss options C82A8EE2-49F1-45CB-972B-63B2C0FFFD92
Jeep Wrangler JL Front axle truss options 09DAA4A5-4ABC-4228-B7CD-1F2BC06C083F
