First regen today. 35k miles.
Kleiss1
Gary
Arizona
2021 JLURD 2018 Mustang GT 6-sp.
My ScanGauge says my 2021 with 26000 miles has had 132 regens.
Kleiss1
Gary
Arizona
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
A couple hundred miles per regen. I think I'm similar. Definitely at least one per tank.
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
So what is the 822 mean? The DPF temperature? what is normal? Thanks
822F is DPF temperature. That 822F seems high because there was a regen going on - diesel fuel injected into the exhaust to burn the soot accumulated in DPF. Otherwise it would be 100-200F lower. Passive regen also occurs when DPF gets hot (personal observation - at above 500F).
DPF temps also increase with engine load. As turbo temps increase with load, so does DPF temps as DPF is part of the exhaust system.
Kleiss1
Gary
Arizona
I’m going to have to add a few more things to my Scan gauge. I just sent it in to be updated. Great customer service.
Deleted User 38384
...36k on it, and have NEVER had a regen...
Jeep Wrangler JL First regen today. 35k miles. images (1)
Take your muffler off, and remove the drain gasket in the cargo tub, and make sure you keep your top on and all your windows closed. Drive around for a month and let me know when you start smelling bleach and are having trouble breathing.
Also make sure to roll down your windows when you start smelling that bleach, no point in killing yourself with poisonous gas. :LOL: ?
Riperoo
Riperoo
Bucks County PA
2021 Jeep JLU Sahara Altitude Diesel
Alright, I'm educated now, I know now that I have had lots of regens, just never had the warning to keep driving pop up. Which still blows my mind! Give it to me! I deserve it!!!
Deleted User 38384
I've actually never had the warning myself either. I do lots of highway driving. My drive to and from work is 20 minutes highway driving, so I'm sure that helps.
?:beer:
Kleiss1
Gary
Arizona
I’ve had the light to continue driving come on twice.
NewbJLUOwner
JLU Rubicon Diesel 2022
Obviously I drive a lot of highways, a lot, the bulk of my driving is on pretty wide open highways, I have a 2021 3.0 with about 36k on it, and have NEVER had a regen. 2 cross country trip and weekly 4 hour drives. Today, driving locally to the gym had my first ever notice of regen, drove around for about 15 minutes and it cleared, I have to say I was kinda surprised, figured I would never have one since I haven't up to this point and it was less than a 1/2 tank of gas since I had a nice 4 hour highway jam. Should I assume that it may be more frequent? DPF is getting older and just feeling its age? Thats my assumption anyway. Haha!!
Hey fellow 2022 JLURD Eco-Diesel owner ?
I'm @33,000 miles
The only time I've actually noticed a Regen took place, was my Fuel Efficiency was significantly off. This happened from my home to airport, which is a 75 mile drive.
Using same roads, speeds, coming home I was bumped 3mpg's
I always average 26mpg going 70
It was @ 23mpg when I arrived @ airport
Back to normal 26mpg @ home
Only time I've noticed or cared. Btw, I recommend using Buc-cees for DEF fill ups, if possible?
Safe travels ?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
?:beer:
Never having the warning is significantly different than claiming to never having a regen. I've never had that warning either, but I've definitely smelled regens.
greige
Robert
2023 farout
On my scan gauge 2, I monitor DPF temp, Regen active?, soot level (STM), and DSR - distance since Regen. I drive quite a bit of highway and rarely see over 30% on STM. However, I get a Regen every 1000 miles on DSR, no matter what. Upon reaching 1000 miles, the STM jumps to 80% and I get a Regen. I did the GDE tune and paid for the notification of Regen, so I see it most of the time.
zouch
Berkeley, CA
XJ, JLUWD
i’ve also never had the “keep driving” Regen warning in 37K miles, but i rarely start a diesel unless it’s going to be running for a while. also, all my vehicles typically get at least one day a week where they’re on the highway for at least a couple hours.
Capricorn
Las Vegas, NV
Yep, that is exactly how it behaved on mine. Except, mine did every 750 miles or so. So it is based on engine hours I guess if we never exceed 80% STM. If you do more highway, your distance since last regen would be higher than someone who does less.
