Fender Chop/split Worth it or a Mess?
Terrymo
Terry
2023 JLURXR 3.6 ET
They call it retention hardware. I have them for mine and I believe @Terrymo has them also. I was sort of forced into it because my previous aftermarket fenders used nutcerts I couldn't really remove. Taking off the fenders is a bit of a project now but I do like the look of the AAL clips.
Yes the price seems a little high until you have removed the inner fender liners a few times without sending OEM fender clip shrapnel all over the garage and hoping you have enough spare OEM clips. Then you’ll thank @SadRobot for the advice
https://americanadventurelab.com/product/jeep-jl-fender-retention-hardware/
SadRobot
Los Angeles
2025 Prius LE
I was able to buy just the plastic washers for $50 + $15 shipping. I bet I could I have had my brother 3D print something for me but I like to support @Adventure Lab (Team) because I do like their products.
yokramer
Snark Incarnate
Did y'all get the I guess is the bolt kit little pieces from American venture ? It's where you don't have white clips showing up in the fenders especially in the front. They're like little black I don't know but you can call him pieces but they going to replace the where the white clips are sometimes you'll see why it up in the fender little pieces where someone did to chop kit. American venture sells it
I tried to get a set of black clips instead of the factory white and they didnt fit my fenders. I put the white ones on and never thought about it again. My fenders will never need to come back off unless I severely mess one up and a little bit of white I never see is worth not spending $100.
SadRobot
Los Angeles
2025 Prius LE
Never say never. I was hoping mine would never have to come off and then I needed a new engine. I don't think I've ever cursed so much as when I had to get the fenders back on after the new engine went back in. 😂 @roaniecowpony wired up the entire RPM Fan Controller while I was putting 1 fender back on with the retention hardware.
yokramer
Snark Incarnate
Youre not selling them at all lol. With clips you just pop it back on after replacing a few.
SadRobot
Los Angeles
2025 Prius LE
Ha well I'm not sure it's the hardware's fault. I think it was a combo of having to get the brackets for my fender liners to line up behind the fender PLUS my shitty nutcerts installed by the 4x4 shop that put my old fenders on PLUS I had to re-use the bolts from my old fender which the shop used a mish mash of bolts. Like most of my Jeep the fender situation is a bit of Frankentein nightmare.
Terrymo
Terry
2023 JLURXR 3.6 ET
Sorry brother…you DO have a Jeep and that $100 IS getting spent.
yokramer
Snark Incarnate
yea but not on fiddly bolts that apparently suck to install, itll go towards ducks and paw print cup holder inserts.
Remorseless
NC
yea but not on fiddly bolts that apparently stuck to install, itll go towards ducks and paw print cup holder inserts.
There had better be some turn signal extension levers in your future
yokramer
Snark Incarnate
Remorseless
NC
