Explain the suspension to me
JHTS
John & Holly
Hope Mills NC
21 Gecko JLU Freedom, 20 Punk'n JL Sport S, 91 Mustang GT, 25 Ranger XL
John - US Army Ret/DA Civilian
Jeep Wrangler JL Explain the suspension to me IMG_8303
I have death wobble 2020JL with 32k miles so I know it’s probably my ball joints but this part has (top left) has play the other side has play but very little is this normal? Everything thing else is tight.
Roky
Roky
If you’re referring to the drag link or tie rod , then yes a little rotational movement is normal……
Jeep Wrangler JL Explain the suspension to me IMG_9763
JHTS
JHTS
John & Holly
Hope Mills NC
Yes tie rod thank you.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Remorseless
NC
Remorseless
NC
GATORB8
CLT NC
@JHTS Just a note on both the drag link and the tie rod. It’s normal to have a little forced rotational play, like if you turn the bar like a motorcycle throttle. That’s the ball joints being ball joints.
If you have lateral play, like if you jerk the bar like a shake weight, definitely could be the death wobble source.
EDIT: So I was thinking that's a shitty analogy for checking for lateral play, but the next thing I thought of was like plunging a toilet. Throwing a hotdog down a hallway? Churning butter? I give up.
JHTS
JHTS
John & Holly
Hope Mills NC
I have lateral play. Where should I start? Ball joints seem to be the most common problem. Your post identifying the parts was most helpful. Nwe to solid front axles. I’m not sure I understand the interaction of the parts.
