Experienced my first Death Wobble
cns721
Rochester NY
'04 WJ, '13 JKU, '18 WK2, '19 JLU, '22 WL74
Software Engineer
I just had my first ever death wobble while driving out for lunch. Went over a manhole and everything just started to shake violently so I had to pull over to the side to get it to stop. I have a 2019 JLU Rubicon that I've owned since Nov 2018. I lifted it with the 2" Mopar lift kit back in Sept 2019. No issues or whatsoever up until today. The only difference was that I just installed a Fox 2.0 TS steering stabilizer last night. Now my question is could it actually be the new steering stabilizer itself? I've heard of people saying that steering stabilizer often masks the death wobble issue so could it have been the OEM stabilizer masking the issue? I would be surprised because I would assume an aftermarket stabilizer would stronger and thus mask the death wobble issue even better.
What's the next step I should take to figure this out? Should I ask Fox for a replacement unit?
TIA!
Roky
Roky
TIA!
How many miles?
cns721
cns721
Rochester NY
Software Engineer
Any other parts added when you did the lift, or only parts in wood box ?
Adjustable track bar for the front. Everything else was out of the wood box.
edit: also bought different coil spring correction pads to avoid the bowing issue the kit had back then.
rohdawg
Long Island, New York
Merchant Marine
Bingo - We have a winner!
That would be the first thing I’d check. @Roky will have more suggestions I’m sure.
Roky
Roky
Adjustable track bar. Everything else was out of the wood box.
With that many miles, you need to start checking things off the list, I’d start with the track bar. Lay under while someone turns steering wheel back and forth, watch the track bar at both ends look for any lateral movement… do the same with tie rod and drag link….if all is solid then jack up the wheel ( do both sides) an inch or so and put pry bar under the tire see if there’s any movement up and down…..my guess is that the stabilizer being firmer it’s not playing as nicely as the old worn one…… I doubt the stabilizer is causing DW itself, it’s just ratting something else out…..
cns721
cns721
Rochester NY
Software Engineer
Thank you for the pointers! I guess I'll have a busy weekend coming up. Once I go through everything you listed, I'll report the findings.
Roky
Roky
Thank you for the pointers! I guess I'll have a busy weekend coming up. Once I go through everything you list, I'll report the findings.
If none of that is the cause, you’ll have to drive it down here so I can put hands on it…..?
TKL223/3
Jon
Arkansas
Jeep JLU Rubicon
Also, check very bolt to see if any are loose
Tank the Jeep
Greg
Charlotte NC
2020 JL Rubicon Diesel
Did you rotate tires? I have had an out of round / balance tire that when it rotated around to the front triggered the death wobble. Check your track bar and ball joints too.
cns721
cns721
Rochester NY
Software Engineer
Did you stroke the fox steering stabilizer 5 times before install?
I did not. I don't recall reading that in the manual.
Rotated the tires about 3-4 months ago.
