Dreaded engine light..
JINO
Jino
Socal
2021 jlurd
So, light came on.
I checked the codes with tazer.
Seems like ABS is having issues.
U0415
U0100
B16B7-15
C1514-87
How would I fix these issues?
JINO
JINO
Jino
Socal
2021 jlurd
2020 3.0
JINO
JINO
Jino
Socal
2021 jlurd
Not just abs, look to be communication problems to me
I'm not sure what that means, is this a computer issue? Would it be covered under warranty? I'm not even sure my 2020 has any left.
Pape
Quebec
JLU Sahara
this is the code descriptions:
U0415 - Invalid Data Received From Anti-Lock Brake System (ABS) Control Module
U0100 - indicates a loss of communication between a vehicle's Engine Control Module (ECM) or Powertrain Control Module (PCM) and another module
B16B7-15 - look to be related to the third brake like
C1514-87 - this one is obscure and most peoples talk about tazer
in any case unless all of this fail at the same time I suspect a communication issue or just a low battery as other have stated.
FYI: I'm no expert just assuming from code you posted and what I was able to google out.
JINO
JINO
Jino
Socal
2021 jlurd
I wonder if tazer is the reason for all this..
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Need to see what codes are in the ABS module.
JINO
JINO
Jino
Socal
2021 jlurd
how old are your batteries?
I'm unsure, purchased this used. It's a 2020.
Battery voltage is a little low, but no issues starting. Offroad pages shows it at 12.7 when on.
