Dreaded JL 3.6 Tick
Bradley 19 Sahara
Bradley
Kentucky
19 Jeep Wrangler Sahara
So my 19 Sahara I just purchased has an engine tick on the passenger side. It’s at a buddy’s shop at the moment tore apart. Intake cam lobes are wore down and a rocker failed. So I bought parts to fix and wondering what oil I should use from here on out? My last change I used PUP 0w20. Should I change to a 5w20 or 5w30?
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I'm going to run 5W-30 in the summer for 6 months, I'm going to run 0W-30 for winter 6 months.
Spank
Your oil wasn't the issue. It's the cheap shitty rocker arms. Supposedly they have improved these, but when I replaced mine, I couldn't tell the difference.
Flip
Johnny
Virginia
Do you know what year they improved them?
Spank
When I ordered these earlier this summer, the dealership told me they've changed the part number twice (AB to AD) since last year. Not sure if that's true or not and if it is, I have no idea what's changed. I compared them to my old ones and they looked exactly the same.
Apparently, they've updated the cams as well.
roaniecowpony
Retired Engineer
Usually, in engineering, a letter change is minor change. A major change will likely get a new part number.
Old Jeeper
Don
US Army Infantry, IT Engineer
100% Synthetic! Shell T 6!!!!!!!!!!!!!!!
Rick4570
Rick
Virginia
2022 Jeep Wrangler
Curious, how many miles on your Sahara?
Spank
Certainly, but this is Jeep were talking about. Even a small change can go a long way.
Nik H
Nik
RI
2018 Jeep Wrangler Rubicon JL
BINGO
SouthernJL
Isom
Georgia
2007 Camry and 2014
So.....I was out of town for a week. We took my wife's car so the Jeep sat the whole week. This morning when I started my 21 JLU 3.6 to head to work, it idled pretty high for a few seconds like it always does on cold starts after sitting for a couple days. But what was new was the loud ticking.
It's rare that my Jeep sits a week without being started. As a matter of fact, I don't think it's sat that long ever in at least the last year or so. After returning from work this evening and letting the Jeep sit a couple hrs, I restarted it again. No ticking.
I've read about the rocker/lifter ticking thing and how it's a common fail on the 3.6. My question is, is the ticking common or expected after the Jeep sits several days? Or does this indicate an issue and I need to schedule an appt to have it checked out?
NWJeepr
Twin Peaks
2025 Wrangler 2-door
It's normal to have some top-end noise on a cold start after the engine has been sitting for a long time. Gravity works on the oil over time, and after a couple days of the engine not running, it's all down in the pan and needs to work back into everything.
It's when the engine is warm and well-exercised and it's still ticking.... then you're screwed.
Maybe take a video of the startup if you can next time the engine sits for a couple of days.
SouthernJL
Isom
Georgia
2007 Camry and 2014
Gotcha. Good to know. I will monitor it and confirm the ticking is only on a cold starts.
