Does your 2.0 turbo rattle/click during deceleration?
Does your JL 2.0 turbo motor make a “clicking/rattling” noise during deceleration?
  • Total voters
    80
Dudley Dawson
Northern Virginia
2026 MOAB 392
For well over a year now, my 2018 2.0 turbo has made a “rattle” or “clicking” noise during deceleration (coasting), most noticeable from 30mph. It’s there at higher speeds too, but harder to hear due to associated wind noise. It seems to have gotten worse over time, and I can now hear it in the cabin. But when the windows are down, the top is back, or doors are off....it’s VERY noticeable (and annoying).
You can read more about it here: https://www.jlwranglerforums.com/forum/threads/turbo-rattle.28478/.
Also in this thread are videos (shared by JLWF members) depicting the rattle/clicking noises (pages 10 and 11).
I’m curious how many other JLWF turbo owners are experiencing this same noise?
Thank you for your answers.
ErAcEr
Matthew (Mateo)
Indianapolis, IN
2018 JLU, 2021 ZH2 , 2018 Z900, 2013 Vulcan 1700
Engineer/Technician
I saw a post a long while back that the Coolant reservoir tank would rattle. Used a zip-tie to clamp down.
Herson
Herson
Michigan
2020 JL Wrangler unlimited rubicon
Just noticed it with the doors off. It is definitely the transmission. When I decelerate and hear the noise, place the shiter on neutral and the noise goes away. Also it is not constant as sometimes will make the rattle noise and go away. Calling the dealership tomorrow for an appointment.
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Mine only does it on cool down after some time at higher speed/loads. Most other turbo vehicles I've had have done similar.
johnnyj
Washington
Jeepless but still a fan.
Mine does it slightly. It's the wastegate. All the ones I test drove also did it very slightly. There's been folks who have experienced much louder versions, who have had turbos replaced. I suspect if one were to use a chassis ear, all of these engines do it to some degree. Folks who say theirs definitively doesn't do it probably just aren't hearing it because it's too faint.
Herson
Herson
Michigan
Not the issue here. I tied mine and it stil does it and is definitely the turbo wastegate actuator. Also the videos posted on the link above show the issue.
joliett
Joel
New York
2021 Rubicon
check the heat shields for the muffler and transmission.
