Do you really need beadlocks?
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
If you live in a state where they conduct vehicle inspections, then they "might" find out. Otherwise, most cops neither know nor care about beadlocks.
However, if your vehicle were to be involved in a serious or fatal crash, then chances are they will find out. They will conduct a post-crash investigation where the vehicles are inspected to determine if any component(s) failed and contributed to the crash. IF your bead lock failed and they're not DOT approved, this could be a basis for negligence, both criminally and civilly. This would be no different if your vehicle had inoperable/improperly maintained brakes, too low of tire tread, etc.
Just curious here, is EVERY SINGLE COMPONENT on your Jeep DOT compliant?
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
I’ve never ran beadlocks and only popped a bead once but that happened after unknowingly puncturing the tire and losing all the air.
On previous TJ’s I regularly aired the 35’s down to 8 psi and the current JL’s 35’s and now 37’s get aired down to 12 psi.
I’ve been wheeling for almost 2-1/2 decades now and thats how I run.
DOOKEY
Andy
Thornton, CO
www.tractionoffroad.com
2021 GCM 392 - 2019 SG JLUR
Wheel Pimp.
How common is it for low psi tires to slip off a non beadlock rim?
Not common. But it happens. How often do you get stuck? Need a winch? How often do you get in an accident? Need a seatbelt or an airbag?
Beadlocks to me are a luxury. You don't need them. They're nice to have so when the bad stuff that can happen happens you have an easier time of getting out of the problem.
You don't need beadlocks. Just carry provisions to seat a bead should they pop off when playing. Or get the beadlocks and remove the worry of being the trail tampon because your tire came off. ?
limeade
Guy
Reno, NV
I fully agree, but have you ever heard or seen of this happening? This comes up every so often on forums and while everyone says it's a thing, it's all anecdotal.
In a previous life, I did crash investigations which looked at these types of crashes. While I never found a bead lock wheel during an inspection, we especially looked at different types of aftermarket components. Everything from non-DOT headlights, lift/lowering kits, etc. These were inspected for improper installation, lack of maintenance, misuse, etc. I've seen non-stock suspension failures lead to crashes.
Typically when I found a mechanical malfunction, it was in the braking system or the vehicle was operating above it's GVWR.
Tool Guy
So Cal
2019 JLUR, 2020 BMW Z4, 2021 Tacoma, 2022 X3 M40i
Our heavy ass JL's are more likely to unseat a bead than earlier generations (TJ, CJ, etc). Unless you wheel a LOT, I don't think they they are necessary. I do have them on my JL as it's primarily an offroad machine.
verapx
Peter
Louisiana
2022 JLUR XR, 1982 CJ-8, 2012 Ram 2500 4WD
No, they're not necessary for your use case. That said, your stock wheels should be fine. So in the end it's your money and you're spending so get what you want and be happy.
I prefer beadlocks myself.
Cycle11111
Alastair
Truckee CA
2019 2 Door Wrangler Sport
I have the ICON Rebound PROs and they provide much the same benefit as pure beadlocks and ARE DOT compliant/legal. I air down to around 12 PSI when off road and have had two friends knock off a bead when out wheeling. One was at night after a very long day and was a huge hassle to deal with - he has since gone to true beadlocks. I did not want a none DOT wheel and is why I jumped on the ICONs.
DOOKEY
Andy
Thornton, CO
Wheel Pimp.
Bulletbill
Tom
Central PA
2021 JLUR
I would change this to say that if I went rock crawling and regularly aired down to below 10 psi I'd probably get bead locks.
Good point. I don’t usually venture past blue trails so never had a real need to air down super low.
RubiSc0tt
Upstate NY
2019 JLUR in Punk'n Orange
Turn Wrenches/ Write code
Debating whether or not to get them (KMCs) on my JLUR, are they worth the hassle and cost or no? How common is it for low psi tires to slip off a non beadlock rim?
(Use will be casual offroading, medium difficulty trails)
Honestly- probably not for your use case. Though they do look nice and are usually more durable.
I've been on the trail since 2005. I've only ever lost beads on my TJ's when I was getting stupid and pushing the 33's below 5psi.
On my JLUR, I run my 37's right around 12psi for Northeastern US forest wheeling (mud, rocks, etc). And I have not had a problem yet. I have a Twin motor compressor with 4 tire inflation system so air up is not an issue.
The only reason I opted for a simulated beadlock wheel with a UMHW rashguard ring is because in the past my steel wheels have gotten bent, tweaked, etc, and alloy wheels have gotten gouged, etc. and I was worried about bead/ rim integrity because I'm running bigger tires on a heavier Jeep.
The only time I'll be putting my tire pressure lower than 12psi on my JLUR will be this summer for beach driving, and that's an entirely different form of wheeling altogether.
Crowbar
usa
20 JLR, 23 JLUR XR
I have beadlocks and am not going to use them on my new jeep. Despite how "cool" and hard-core beadlocks look, I do not Need beadlocks for the way I wheel. I haven't needed to air down below 15psi. I don't need the potential liability issues. I don't need the potential legal issues.
blnewt
New Mexico
Just ask @cosine he knows!
OP, sounds like you're not planning to run trails that would require airing way down, should be fine going down to 15 psi. No need for any more reinforcement to keep the tire on the bead at that psi as long as you have a proper width wheel range for the tire you're running.
Steak
Northern Virginia
2016 Honda Accord, 2013 Ford Escape, & 2003 Acura RSX
Airing down to no further than 15 psi is the rule-of-thumb for non-beadlock wheels. I have a 2020 JLUR on 35’s and I’ve run numerous Medium Difficuly trails in Moab, Sedona, Uwharrie, Windrock, and elsewhere, and I always air down my non-beadlocks to between 13.5 and 14.0 psi. Never popped a bead. But, maybe I’ve been fortunate/lucky!
