Disappearing Drain Plugs
Plumbean
New York
JLU Rubicon XR
I have now had a second drain plug go missing from the driver’s side floor. Apparently pushed through and lost on the road somewhere. Anyone else have this problem? I made sure when I installed this one that it was seated properly. It lasted 3 weeks.
ArcadeTracks
PJ
Pittsburgh, PA, USA
I've had the sides shred off one of mine, but it hasn't fallen through the floor ... yet.
My floor mats came with their own set of plugs, so I do have a spare set ready.
Are your plugs directly in the floor, or in mats? And are you sure you have the right size? (I don't know if JKs have different plugs, some off-brand ones might be slightly too small, etc.)
azjl#3
North AZ
My 23 is showing carpet below drain plug, that has no cover. Brand new.
BDinTX
Dallas, Tx
If you have the all weather mats, they’re molded with a piece that will go into the drain hole. Suspected that was a contributor when I my lost own plug so I cut it off.
jludave
The Isle of Long
IT Manager
You need to cut away the piece of carpet covering the drain plug. If you look closely you’ll see that it is just held on in a couple spots. It also sounds like you have the OEM slush mats that have the plug/hole for the drain built in.
Plumbean
New York
JLU Rubicon XR
I cut away the carpet piece a long time ago. The OEM slush mats have a hole in them at that spot. Are you saying that the drain plug is now supposed to plug into the mats, as opposed to into the floor, and then the mat plugs the hole? I had the plug underneath the mat, which was where it was from the factory (it was also under the carpet).
jludave
The Isle of Long
IT Manager
Yes. Otherwise the front mats don’t lay flat. Look at the bottom of the front mats. You’ll see the piece that sticks out and goes into the drain hole. The drain plug then goes into the mat to seal the drain hole.
BDinTX
Dallas, Tx
The reason I cut the bottom part off the floor mats is because they don't seal to the floor. If you move the plugs up into the mat, water and damp can still come up and get into your carpet. Cut the mat short, plug both.
Jeep Wrangler JL Disappearing Drain Plugs IMG_2203
Jeep Wrangler JL Disappearing Drain Plugs IMG_2204
