Difficulty filling the tank completely
Texcal
Erik
Oakland, CA
2018 Wrangler Rubicon JLU
Turns out that was just an issue with that particular fuel pump. I haven't had the problem since going to other stations recently. I get the usual amount back in the tank now, minus the reserve that is always there when the fuel light comes on.
Glad you figured it out. I have the same problem with an Arco gas station near my house. Everywhere else i've been I have been able to fill it up properly. I also wait 30 seconds after it's full to top off again. I can usually get a bit more in the tank while the gasoline settles into the tank.
Ormond Beach, Florida
Retired at 55 ..
@Sean L
@Bswen
Well, my keeping track of the pennies ... grabbing pennies all my life and lets say making them work for me paid off..... as I retired at 55, with a pension, and $ in the bank to enjoy early retirement with. :like:
Sean L
Sean
North Carolina
@Sean L
@Bswen
Worked out pretty well for you then, but I doubt it was just the extra gas in the hose that got you in to that position.
Bswen
Atlanta
2018 JL Sahara
Nice, not a lot of pensions out there. Government work? My mom retired at 55 with full pension, plus personal retirement etc... A life putting up with idiotic bureaucrats from the inside.
Rhinebeck, does that mean "stopper of all things pay it forward" in Swahili or something? Give that next guy thats barely making ends meet that .003 gallons! Scrooge!
JeepCares
Auburn Hills, MI
JL
Ive filled up every week for a couple months from “full” to empty. I cannot get it any higher than 15 gallons, most of the time it doesnt even make it to the full mark. I cant figure it out. Has anyone else figured out a solution or is it really just programmed that far off? Side note, downward inclines suck in traffic with lowish gas. On an incline ive had it go from 100+ miles left to 15 miles. In stop and go traffic it gets a bit worry some
Hi Moto_21,
We've noticed that you are reaching out to other forum users for advice at the moment. If you decide you want to have a dealership check out your concern, Jeep Cares is available to you if you would like extra assistance while your Jeep is at the dealership. If you have any questions beforehand, you can always send us a private message.
Lydia,
Jeep Social Care Specialist
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
It doesn't look like I'm getting the full 21.5 either. Before I fill the tank, I note the remaining range and avg. mpg. I divide the range by the avg. mpg to calculate the gallons left in the tank and add that to the amount of gas it takes to fill. It's been coming out right around 19. Based on the fuel gauge being just under the full mark when I fill it, I'd say my tank is not getting full.
Fixed - gas tank replaced
Jeep Wrangler JL Difficulty filling the tank completely jl fuel gaug
Jebiruph
Jerry
Iowa
Wonder if its the tank sending unit then? Mine still wont read full
I think it is a problem with the tanks that won't fill all the way. My impression is maybe gained a couple gallons based on topping off a half full tank. My JT fills all the way as it should and I didn't get any push back from my dealer when I requested the tank replacement.
lalalofsky
Ben
Lawrence, Kansas
2020 JLU Sport
I know this is an older thread but when I fill from empty in my 4dr i max out between 17-19 gallons. Are people actually getting 21 gallons on a fill up?
txj2go
DFW
There's one way to find out- get on the highway and drive until you run out of gas. Then you have to put gas in from a jerry can and drive to a gas station to continue the fill up to determine how much gas you can really fit in there. Until you do this you don't know if you have 1 gallon reserve or 3 gallons reserve. But I wouldn't take chances on what the reserve is unless you are carrying extra fuel with you.
About 20 years ago I had bought a different car and people online said that it had a big reserve because they couldn't put the full state tank capacity in it. So one day I was very low and I kept driving because of the supposed amount of reserve, but I ran out of fuel. I walked to a gas station and borrowed a can, then drove back to the station and carefully filled the tank completely. I found out that yes it did want to shut off about 3 gallons before full and i could carefully get another 3 gallons in there. My JLU seems to do the same thing but I haven't tried to put more fuel into it yet.
bllprk
Kalamazoo, MI
2008 WK CRD
Any updates here? I have a 2018 and can't get the gauge to full. Hoping to find an individual component I can replace rather than a gas tank assembly.
BetOnBlack
Princeton, TX
2019 Rubicon Unlimited
Supreme Leader of IT
Once the pump stops. Pull the nozzle out about half way. Wait 30 seconds to a minute, then proceed to fill up again.
I have issues with some pumps where I can't even get a gallon in before it cuts off. I have to pull the nozzle out a bit to allow air to escape to equalize or something. Doing this i can get the gauge to completely full.
Old Jeeper
Don
US Army Infantry, IT Engineer
As I travel often for business like to squeeze all the fuel I can get into the tank. THe Jeep is very difficult to give up a full tank.
Jeep tank is 17.5 gallons and the only I can get there is this:
Stab the inlet and put the nozzle as the lowest setting.
Watch the fuel gage and just at it gets at the bottom of the marker for FULL, click off the nozzle and dribble it in till is backs up in the pipe, rock your Jeep a little bit and it will go down. Then let it set for about 30 sec and you can add more at that time and in most cases almost a half gallon more.
