Differential fluid
Ormond Beach, Florida
Retired at 55 ..
Currently, the M200 is referred to as a Dana 35. Do your research before you spread more misinformation.
Most people even most friggin asshats know either nomenclature is used.
Most ads, articles, etc. list /call it by either or, or both.
Jeep Wrangler JL Differential fluid Screenshot_20240223_091603_Firefox
Lofty
Casey
Ohio
JL Wrangler
Hello everyone,
I have a question regarding the fluid to be used in my differential. I have a 2018 wrangler JL 3.6 from what I can tell I have a Dana M200. The manual states I should use 75W85. I also emailed Jeep Customer Care, they also stated that according to my VIN I have a Dana M200 that requires 75W85. This is where the confusion comes in, according to online research and what others have said in the forums the M200 requires 75W140.
So what informations should I go by?
The correct oil for the M200 axle is 75w140. (1.15 Liters)
Gunfighter
P.J.
West Michigan
2021 Jeep Wrangler High Altitude
Trying not to get warning points
Well, after consideration...decided to just go 75W-140 all around. Changed out the 75W-90 in the front yesterday. Could I have waited - sure, but just wanted to be done with it - Having ONE diff fluid for both axles is easier. Have enough oils and fluids, grease, this and that in my garage might as well make a very minor consolidation ?
wreck99
Matthew
SC
2024 JLU Rubicon, 2019 RAM 1500 Bighorn
I'd be interested to hear about your experience with 75-140 all around. Gas mileage, performance, etc. Also which brand you went with. I believe I read that Dana recommended 140 on both and Mopar puts the 90 on there for CAFE reasons? Also does yours have the drain plugs? Mine doesn't so I'll have to pull the covers. I still have a ways before I need to change the fluids probably (only 2k miles so far) just doing some homework first.
CarbonSteel
100%
In the end, your right foot, a headwind, or a heavier load will have more impact on MPG than a viscosity change ever will. There are so many variables that no owner is going to be able to consistently and accurately measure any MPG change due to oil viscosity.
You need a controlled environment and a lab for that...
azwjowner
Phoenix
100%
It’s been done: https://archive.epa.gov/nrmrl/archive-etv/web/pdf/03_vs_conoco.pdf
The EPA found a 0.97% improvement in fuel efficiency using 75w90 instead of 75w140 in a 2003 F-150.
Not too shabby. A percent here, a percent there, spec 0w20, etc., and suddenly you’re at 5% and your vehicle gets 21 mpg instead of 20….
CarbonSteel
In a lab under perfect conditions.
0.97% of 18MPG (which many Jeep owners do not see either) is 0.1746 MPG.
You will not see any difference in any reasonable length of time and given the operating temperatures and weaknesses in the Jeep axles, 75W-90 would not be my choice.
azwjowner
Phoenix
I run 75W-140 for all the reasons you've previously enumerated, and in fact I've switched to Amsoil Severe Gear based on your reports. But just because you won't notice the difference from tank to tank, it still exists. If you were at 18 MPG, after 100,000 miles, that's ~54 less gallons of gas, or a savings of perhaps $200. Again, I would rather have the extra protection of the heavier weight oil and $200 over 100,000 miles is a very small amount compared to the other operating costs. But it is a difference. (Multiply by 100,000 Jeeps and now Jeep owners are spending $20 million extra on gas to run thicker oil. If it turns out that their differentials would have survived either way, which is likely the case, that's all wasted money. Let's not kid ourselves -- we are optimizers, obsessed with the longevity of our mechanical devices, while the reality is that changing the gear oil every 50K miles or so is all that the average person does and their axles usually last just fine.)
Gunfighter
P.J.
West Michigan
I don't know or care so much about MPG - my last vehicle was an '06 V10 F-250 w/ 4:30's..maybe saw 10 mpg or thereabouts. Here is what I am using for the diff:
Jeep Wrangler JL Differential fluid 1708798796374
CarbonSteel
In principle, I agree.
In reality...it is just not going to happen--far too many variables in operating conditions alone that will more than negate any such miniscule savings.
Smokey_The_Rooster
Smokey
Earth
Jeep
Reality is , I could care less what a guy/gal does with his JL..
So you could care less meaning you do care some?
FYI: It's "I could not care less". Don't forget the "not" or "couldn't" in that saying. Otherwise, you do care!
Do your homework if you don't believe me. Lol
Smokey_The_Rooster
Smokey
Earth
Jeep
? . Most people do not say that correctly. Just here to share a little knowledge, and gain a little knowledge. Glad I could educate.
Smile more, life's too short.
wreck99
Matthew
SC
Nice! I was between AMSOIL and Valvoline squeeze packs when I did our RAM 1500 last week. First time doing it and good practice for the Jeep haha. I read good reviews from both so figured I couldn't go wrong. I ultimately chose Valvoline because it was more readily available in town and was about 1/2 the cost as AMSOIL. I'm not sure yet which I'll use for my JLUR but at 2400 miles I have plenty of time to decide.
Gunfighter
P.J.
West Michigan
