Krawler
- Apr 21, 2019
- Los Angeles
- Rubicon
Do you still have all your original components? Maybe it makes sense to go back to stock and start over. The caster will help your steering/wander issue. There will always be a little bit of wander, these things don't have the steering precision of a Porsche 911.So I have a rancho track bar with about 5K miles on it. I replaced first before the synergy came out. Do you think there is a possibility that bushing is bad? Seems fast considering I haven't wheeled it since before and just daily driving to and from work. Debated spending the 275$ for a new synergy track bar just so everything matches. Feels like a waste but whatever at this point.
Stock jeep - no wobble, little wander
new track bar - no wobble, less wander
new tie rod, drag link, flipped stabilizer - Bad wobble, same wander
new alignment, retorqued everything, new stabilizer, less wobble, same wander
Ball joints are good. torqued and no movement. took cotter pins off tie rod ends and checked torque, all good. Some suggest caster can help. You don't think so? There aren't that many moving parts. so dumb.
My installer was adamant about not upgrading/changing any components to fix issues as the original (with low miles) should drive perfectly fine. I was skeptical, but he was right. My issues had nothing to do with components as I alluded to earlier.
