Dead Jeep. No Power
El-Jefes-Red-Rubi
Allen
Sparta, Georgia
2022 Sting Gray JTR
Went to use my JLUR tonight and it’s dead. Had to use the key to unlock. Proximity dead, fob doesn’t work. No interior lights, no dash, nadda.
jeep is a 3.6 automatic. All stock. Had ESS and main battery die about 6 months ago. Did the ESS delete, pulled fuse and negative cable. Installed new main battery. Jeeps been fine electrically since then except the one post I made recently where the lights went crazy all by itself in the middle of the night.
Any idea why it would just die? Didn’t drive the past two days but on Sunday the Battery was charging at 13.7 according to off road pages.
Any help is appreciated
roaniecowpony
Retired Engineer
Yeah. I noticed some similar things on other threads. Gremlins.
Joe's_Roxy
Arkansas
2018 JL Rubicon, 2009 JK Sport, 2006 LJ Sport
Quality Manager
What's even more confusing here, is that HK1s is marked as being the OP, when El-Jefes-Red-Ruby is the real OP?
Hello, am I hallucinating? ?‍??
If you make a post, and copy the profile picture with the "OP" on it, and set that as your profile picture, all your posts will look like you were the OP. Really don't know why people would want to do that but whatever!!!
Rocket_Matt
Merritt Island, FL
2019 Jeep Rubicon JLU
2. left your key too close to the jeep, the car can somewhat find the key but not quite, keep draining the battery, use a metal box to store the key.
Is this really a thing? I keep my Jeep in the garage and the Fob is in it's holder the entire time and I've never had an issue.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Your jeep and key aren't constantly searching/ connecting via a poor connection. It's like the fast drain on your cell phone when you have sporadic service. Either good connection or no connection are fine. It's the intermittent connection that can cause a drain.
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Pull fuse cover and make sure all fuses and relays are pushed all the way in.
El-Jefes-Red-Rubi
El-Jefes-Red-Rubi
Allen
Sparta, Georgia
2022 Sting Gray JTR
Update. Disconnected and charged the battery all day. When I disconnected the battery was at 4 V. As stated before I’m in a single battery configuration with the ESS battery disable infused 20 pulled.
after charging the battery all day, it’s up and running again. The following items are no longer available to me. Backup camera, automatic HVAC control, off-road pages, XM satellite.
I read one post that stated the car just needed to sit with power for an hour or two and all those things should come back. Does anybody have any experience with what I’m seeing ?
Jeep Dude
duuude
duuuude
Jeep Wrangler JL Dead Jeep. No Power 1678335394719
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Battery was at 4v? It won’t last long. Might as well get a new one, H7 group 94R.
Did you disable ESS after you took the aux battery out of the circuit?
El-Jefes-Red-Rubi
El-Jefes-Red-Rubi
Allen
Sparta, Georgia
2022 Sting Gray JTR
it is new. Something is draining it.
after charging the battery yesterday and getting the jeep to start, I went for a long drive hoping my system to come back online. They did not. I stopped by the service department at my local Jeep dealership and spoke to him what was going on. He wanted me to give it a full 24 hours to see if they updated and if not then to make an appointment to drop it off, he had mentioned the 8.4s sometimes go out and seeing that that’s the brain of the canbus system that’s where they wanna look at first.
