Cube mounting Light
voodoo11
New Jersey
JL 2018 Rubicon
melendez69
Marc
Waxhaw NC
...huh?
Curious if it's repurposing a HAM/Antenna mount like this: https://www.hamradio.com/detail.cfm?pid=H0-006551. Like it because it doesn't impede the future possibility of putting down the windshield as I haven't found a cube mount that will allow this functionality.
That's what I'd like... something that allows to lower the windshield and also pivots the cubes. I like the Rigid side mounts, but not at close to $300 since there's currently a similar model being designed that allows for pivoting the lights. I believe many others would be interested. It's a pain in the ass to keep removing/re-mounting when you want to lower the windshield.
voodoo11
New Jersey
JL 2018 Rubicon
Yeah. This is @Maximus-3 JLUR. Hoping they respond publicly to our questions on that mount!
voodoo11
New Jersey
JL 2018 Rubicon
Ask and you shall receive. From @Maximus-3 : https://maximus-3.com/jl-bumper-accessories-/maximus-3-jl-cube-led-light-brackets
melendez69
Marc
Waxhaw NC
...huh?
voodoo11
New Jersey
JL 2018 Rubicon
That's some nice detective work... I've scoured the forum & I don't see anything on these...I'd like to know if anyone has these. I'm gonna give these a try; see if there's much vibration. If they don't work out... well, it's only $100.
Good looking out. I appreciate it.
Keep me posted! Also want to know if I can mount it under the cowling, closer to the a pillar vs down the hood. I have held off buying cube lights because the limiting mounting options but this might compel me to buy some. Please post your results.
melendez69
Marc
Waxhaw NC
...huh?
I certainly will... I was also thinking closer to the windshield since they mount under the hood. I'm waiting to hear back to see if they offer a forum discount.
melendez69
Marc
Waxhaw NC
...huh?
@voodoo11
So here's the finished product. They're only designed to mount under the hood fairly close to the cowl, but they're close enough to the windshield for me. They're designed to fit right in the bolt locations. They're sturdy and the rubber bumpers keep from making contact with and scratching the paint. I started her up, and there's no vibration. You can loop & secure the wiring to keep them tight to the bracket (I'll get around to that). I'm satisfied with these, and for under $90 they're great if you want the freedom of lowering the windshield without the hassle of disconnecting & removing cubes...that was my goal. When I get some darkness down here, I'll post some pics to show any glare bouncing off the hood. Thank you for bringing these to my attention, and my thanks to you as well, @Maximus-3
If you don't want the steel making direct contact with the paint, there's always 3M film for protection.
https://www.amazon.com/dp/B01LZYSXZJ/?coliid=I38HOPHUJNPPNK&colid=3VSS4SVDL19B1&psc=0&ref_=lv_ov_lig_dp_it
Jeep Wrangler JL Cube mounting Light maximus_001
Jeep Wrangler JL Cube mounting Light maximus_002
Jeep Wrangler JL Cube mounting Light maximus_003
Jeep Wrangler JL Cube mounting Light maximus_004
Jeep Wrangler JL Cube mounting Light maximus_005
Jeep Wrangler JL Cube mounting Light maximus_006
Jeep Wrangler JL Cube mounting Light maximus_007
voodoo11
New Jersey
JL 2018 Rubicon
@voodoo11
https://www.amazon.com/dp/B01LZYSXZ...olid=3VSS4SVDL19B1&psc=0&ref_=lv_ov_lig_dp_it
Wow .Looks great .Have any profile pics from the side?
melendez69
Marc
Waxhaw NC
...huh?
I'm running an Inspired Engineering 6-Cube Red Series (spot)... here's what it looks like in the cold, dark night. The cube is mounted as far left as it can go. My M3's a bit dusty... don't judge me. ;)
Jeep Wrangler JL Cube mounting Light driver_001
Jeep Wrangler JL Cube mounting Light driver_002
Jeep Wrangler JL Cube mounting Light driver_003
47Jeepster
Tom
Queen Creek, Arizona
2025 JLUR X ... 2023 JLUR Diesel ... 2018 GC Summit
@melendez69 ... thank you sir. Those pics helped.
Looks like the Ace mount places the cube the lowest of all the over the hood mounts. The Rough Country mount only raises it an 1/8" of so more, but moves it off to the side. The KC mount kicks the light up an inch or so and moves it off to the side like the Rough Country mount ... it's also a very sturdy mount which should not have vibration problems. The GoRhino single mount looks like it might kick it up a inch and a half or so ... but, again moves it off to the side. Very sturdy looking mount. Light on the hood from the GoRhino mount isn't that bad ... still, more than the Rough Country mount, which doesn't make sense unless you've got your lights aimed downward more.
Plan to visit the Rigid Industries facility on Monday to ask some questions. Maybe I can locate @campbellshotrods for some extra credit help. What do you think Josh?
Your pics show the top of the fender and the side of the hood lit up quite a bit from the side mounted light. Was that your impression in person? Those brackets look like they would be great with the cube (fog pattern) aimed outward at a 45 angle to increase side and cornering visibility.
melendez69
Marc
Waxhaw NC
...huh?
I may have the lights angled slightly downward...I've been adjusting to find the right angle so I don't blind oncoming drivers before I can hit the switch off. The fender mount is lighting up the side of the hood...It's a spot and I plan to adjust the angle a bit, but I'm not sure it's the right pattern. don't need them facing forward since I have the Rigids up top. If it weren't raining down here that would've been my project for today.
It's great that you're near enough to visit the Rigid facility... I hope you get some good information there. Their dual side-mounted bracket is the one I'm waiting on...he's developing one that pivots the lights outwards. The model they have now is about $300, and I'm pretty sure anything newer would be about the same.
melendez69
Marc
Waxhaw NC
...huh?
Here's a cleaner install of the @Maximus-3 mounting bracket, with the wire tucked away. Looks much better with much less exposed wire.
Jeep Wrangler JL Cube mounting Light bracket_001
