benny_rt2
Benny
Baton Rouge Lousiana USA
1989 YJ - 1999 TJ - 2004 TJ
awesome build thread. I really like the rock krawler arms, I had the stretched wheelbase RK setup on my TJ in my profile pic and loved it
I'm saving up for a JL rubicon. I have a question about the front motorized sway bar disconnect.
When the Rubicon swaybar is disconnected where the two halves of the swaybar interlock, is it still possible the sway bar links attached to the sway bar to limit droop and flex? It something I thought I noticed on other JL stock rubicons (not yours) when they disconnect and flex out.
Perhaps I would still invest in old school manual disconnect pins at the links even with the convenience of the motorized disconnect to get max flex, although yours looks to flex super.
Thanks
Jeep Wrangler JL Crystal Rubi build… 1643987798897
Roky
Roky
Roky
Thanks
Thanks brother……
It’s the style of the oem links that are limiting. They have fixed bushing on one end, and the pivot bolt on the other end. That coupled with the length, they’ll bind up before the sway bar can fully drop out because of the amount of misalignment that occurs when articulating.
In the pic I’m connected, but in the other pic that was with this one I’m unhooked, and there’s only maybe a quarter inch difference.
It’s all due to the style of links. If you use a link with a heim on each end that will let misalignment happen and the bar drop out without binding.
Im using RK no limits links………
If you do a lift and use longer links it will drop out better, but the links with standard bushings, the bushings are going to wear out quicker if you wheel it often.
BeachPilot74
Garrett
Colorado Springs
2022 JLUR XR, 2013 F-F150
Airline Pilot
Thanks brother……
Dammit.. Just more crap I have to buy!!! These will go great with my JK Sus kit I am going to install on my new JL.
Roky
Roky
Roky
J.E.E.P. Just Empty Every Pocket……and Bank account, kids college fund, sock drawer, couch cushion…………..:computerrage:
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Hey man! How’s the shakedown of that fancy “steering stabilizer” going?
Roky
Roky
Roky
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
Roky
Roky
Roky
I was recently asked if I’ve noticed any sag in my springs, I have not, it’s dead level…….
Jeep Wrangler JL Crystal Rubi build… 31C137BD-8DAA-47A0-8864-FAC266FC4529
These springs been on about 3 years now. I recently loaded 10 - 40lb bags of water softener salt in the back. 400 pounds made it only squat 5/8”. A 1/16” under 10 to a 1/16” under 3/8”, I’m calling it 5/8”.
Jeep Wrangler JL Crystal Rubi build… 82D2C811-162B-4D05-9F0F-61CDA0757DAA
Jeep Wrangler JL Crystal Rubi build… 2C8FD34F-4478-4B89-9DD1-6BA9BC422261
Jeep Wrangler JL Crystal Rubi build… C9B78B9F-4CEE-4422-B30C-1C2226BC57B4
I have about 250 back there daily, 37” spare on a beadlock rim 110lb, LoD steel bumper 80 lb, and EVO tire carrier 60lb.
So I’m happy with how these RK 3.5” springs are aging……..:)
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
It sure sags less than my coilovers ?? just the empty flat bed on there brings me down 1/2” lol
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
We run the same salt ;)
Roky
Roky
Roky
Adjusted my E brake handle. I could pull it almost halfway up before it started clicking.
Wasn’t to bad….
remove 4 - 10mm bolts, raise the back of console, prop it up with something, put a couple extensions together with deep 10mm socket give it a few twist (righty tightly) let console down try it, adjust accordingly, put back together, easy peasy, there’s videos on it.
Jeep Wrangler JL Crystal Rubi build… FC2D0A1E-0FD8-4F7C-9E93-50885EF91966
Jeep Wrangler JL Crystal Rubi build… C3C52A5F-E28F-4C8B-A59B-2743E7F8F3E3
Jeep Wrangler JL Crystal Rubi build… 34438F26-4749-44CF-A249-7168BC740E63
hoag4147
Colleyville, TX
2022 JLUR XR
Wasn’t to bad….
Sounds easy but How the heck do you see under there. Not sure I could lean my head enough for the reader glasses to be effective lol. I guess feel around with extension until grabs
Roky
Roky
Roky
That was the hardest part of the whole thing. I ended up using my phone camera…?
