Moto_21
I run a quad compressor set up ?When you say drugs to mean Jeep drugs like a dual ARB setup ?
Do more "Mexico" runsI run a quad compressor set up ?? hahaha. I need to put real drugs in there to pay for my mods ???
Not a bad idea ??I was thinking if I could fit my winch control solenoid in that box somehow..... close to battery for wiring and sealed to keep muck out of it.
My tunnel collapsedDo more "Mexico" runs![]()
No tunnel needed, no walls in Cali.My tunnel collapsed
True hahaNo tunnel needed, no walls in Cali.
I will probably be hitting you up on this to find out the tricks of getting cables from baby battery pulled outGot my battery today and got it installed…….. oh….. if only it was that simple, ? ……
I was gonna run a 40 amp fused jumper wire from N1 to N2 terminals in the fuse box, disconnect the aux negative cable from main negative cable and delete the aux battery.
But the more I thought about it, I wanted the aux battery out of there. So that’s what I did..
I have Artec inner fenders so getting to the aux batt. and getting it out was 5 minutes.
Getting the cables up out of that location and up to the main battery was a PITA…….had to take the 6 cables off of the fuse box and pull about 6 Xmas tree clips out to get enough room to get them up and out of there……..
Taking the aux battery out you attach the aux positive cable on the main positive cable and unhook the aux negative cable from the main negative cable and tape and tie it up out of the way.
Thanks brother….. sure appreciate it…. It has been/is a lot of fun…..Just beyond next level in most every aspect, even the cat lol
Just jaw dropping the work and thought you put in every mod on that bad boy!
And for the type of wheeling you do those parts aren't on a holiday cruise![]()
