Corrosion appearing in multiple door hinges.
Colombian Guy09
Christian
Lake Worth, Florida
2019 Jeep Wrangler Sahara
I have recently seen that corrosion is appearing on many of my door hinges on my 2021 JLUR Gecko but the weird thing is that on one door it’s both hinges and on another door its just one hinge from what I can see. I have entered a claim with Jeep to get all the door hinges replaced because I don’t have time to take it to the dealership I have to go. Has anyone had a similar situation?
Old Dogger
Bill
Cave Creek Arizona
This is an ongoing issue with many, but not all of the JL's. I am not really sure, that the factory has a permanent fix for this issue. Some have reported having this repaired, more than once.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Is it just on the hinges, or on the door too?
Note that you need to take it to a dealership so the appropriate paperwork can be started. I'm thinking the warranty is 5(?) years. Be warned that it's several thousands of dollars of work for them to "fix" it, so don't wait.
Colombian Guy09
Christian
Lake Worth, Florida
I have a 4 door by the way
Oh yea I know that for sure I had to get my hood repainted and hood hinges replaced.
Colombian Guy09
Christian
Lake Worth, Florida
From what I see it’s just the door hinges. I’m planning on taking it to the dealership on Saturday
churlk
2021 Rubicon Gecko
Is your gecko a rubicon?
pablo_max3045
Germany (ex-pat)
2019 Rubicon
Engineering project manager
Make sure to check closely at the bottom of the doors. Likely on the tailgate as well. "It's a Jeep thing" in that they did a complete shit job.
Mine was very hard to detect with black paint, but I found loads of areas with bubbling paint. Had to have all the door resprayed.
Colombian Guy09
Christian
Lake Worth, Florida
Yea I’ve checked the doors and on my end I don’t know if I see any corrosion. I got rear ended last year so I got a brand new Tailgate door so that one should be fine 😂
Tacoman03
Matthew
Fayetteville, AR
2022 Bronco Raptor 2024 Land Rover Defender 110 2024 Wrangler 392
Hoping they got all this fixed by the 2024"s!!!!
Bills2ndJeep
Bill
Joliet
2018 JL
TheNewGuy
Wes
NH
2021 Jeep Wrangler Sport S 2 door
I have an 08 and just left them. No issue other than looks, but over time the other scars of use kind of mask it.
Your 08 JK has steel doors so it won't spread past the actual hinge. The JL doors are aluminum
TheNewGuy
Wes
NH
From what I heard the door hinges have a zinc cover to avoid the different metal direct contact and the hood is another material or something like that
It's not different metals. The hinges and doors are both aluminum as is the hood. The zinc shim was added to the hinges as a sacrificial anode to delay the corrosion spreading to the doors. Too early to tell how effective it will be. I'd check the inside seam on the bottom of your doors and hood for signs of corrosion because that's where it starts before it eventually spreads to the outside of the panel. Once there is corrosion in the hem flange, there is no repairing it, the panel needs to be replaced as per the TSB
