Cooling problems with 3.6
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
When was the last time you washed all of the mud off of the radiator?
No more then a few days after I go mudding... That is just from yesterday
No IFS
So Cal
JL Rubicon
It worked great for years then the dealer touched it now it doesn’t work. Back to the dealer and have them fix it. If you were going to do the job yourself you should’ve done it before you went to the dealer not after.
TOTL Innovations
Rock Sponsor (Level 1)
www.totlinnovations.com
2008 JK
Im also trying to find a grille & hood that allows more airflow - please send any recommendations
An OEM vehicle shouldnt have the issues you are having in the conditions you are describing so I think something more serious is going on which upgraded parts may help with but will only be masking the underlying issue in the long run.
That said if you are still looking for upgrades, have you seen our H.E.R.O Hood?
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
Replace the radiator.
I think I’ll just flush the coolant a few times with distilled water then replace it properly and see what happens
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
Unfortunately I’m 1500 miles from the dealer that did it - otherwise I would - nice name btw
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Flushing won’t get the packed mud out of the fins. That fine dust settles in there and sets up like concrete. The radiator is cheap and easy to replace.
Petey
Pete
Miami
2020 jl sport manual
Just curious if the Jeeps going to the desert countries Saudi Arabia etc have larger radiators??
No I haven’t been adding anything - and Yes the cooling issue has been persistent for a year, the timing faults 4 weeks, both unresolved - dealer is awful here and is still waiting on new ECU (it’s one of the first production 2018 JLUs so it’s around 4 years old and I use it consistently for off-roading in -20 to +125 degree weather) - the past few weeks it is has been nothing but trouble but somehow has not died on me, debating whether to sell/replace or completely overhaul in a few months
overheating coolant happens in 3 main situations: 1. Driving in the Mojave uphill for a while in extremely high temperatures attempting to maintain 50mph+ 2. Driving up I70 (7-10k ft altitude) and trying to climb at 50+ mph 3. Driving on a flat highway at high temps and high incoming winds
From what u wrote here I would say u need a radiator with more cooling capacity.
LooselyHeldPlans
Brandon
SW Colorado
2020 3.6 JLUR
Several
I'm in Denver, so a little warmer than you. I have 315s and the 4.10 axles. I run the stock plastic bumper and have it hollowed up to fit a winch.
the only time I've ever ran too hot was when I was having ESS trouble and revving the engine while sitting still to try and push some juice into the battery. Never while moving.
I think you've got a mechanical issue.
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
What if I use a pressure washer on it?
mwilk012
Oklahoma
Service
You can’t get past the condenser on the front side without removing the radiator. You can buy a radiator for less than $200.
The symptoms you are describing are one of two things, either reducing cooling system heat transfer capacity, or a blown head gasket. I’d like it to not be the second thing.
Joaquim
Joaquim
Joaquim
Boulder
2018 JLU Sport S
Autist
Alright, thanks for the help - would you happen to the know the part # for the radiator? and would you recommend upgrading to a different one?
mwilk012
Oklahoma
Service
I’m 99% sure it’s 68314786AC
