Compass stopped working
mgroeger
mgroeger
Southern UT
2021 JLUR 2.0T
So I’ve had my JL for about two months and all of the sudden the compass is intermittently working. For no rhyme or reason when I start jeep sometimes it’ll be working and other times it won’t.
Disconnect the three negative battery terminals from the battery over night. I did this and it reset mine. Do a search on the forum for which three terminals I'm referring to.
Corodimas
Ryan
Long Beach Ca
2018 Jeep Wrangler JL
Thank you for the tip, I’ll try that. Have you noticed the compass staying on after the negative terminals were disconnected?
acole10000
Adam
2018 JL Rubicon Unlimited
I am sad your compass stopped working, but I guess mine was never installed as I cannot find it in UConnect...Any ideas?
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
I am curious to where the three negative terminals are,I only found two
SRQgunner
Russ
Sarasota FL
2018 Jeep Wrangler JL Unlimted Sport S
I JSU picked up a certified pre owned 2018 Wrangler and have the same issue. Sometimes it works sometimes it doesn’t.
did you find a solution
mgroeger
mgroeger
Southern UT
2021 JLUR 2.0T
While it is working go to a parking lot and drive in a circle. I'm not joking, that's how the compass gets calibrated. If you have OCD like me you can then drive in a circle in the opposite direction for thoroughness sake. :)
SRQgunner
Russ
Sarasota FL
I did and it seems to be working now
